HELP! [EdiToaded: '01 Elite Slower After Mods]
2001 honda elite S serious issue. so my setup was a unrestricted exhaust stock jet removed stock variator ramp and i went 39 on gps now i changed to an 85 jet and cut second tab in air box and gps speed is 34mph HELP!!!
Re: HELP!!!
Greetings, Ryan:
Your previous setup isn't too clear. If your bore and pipe are all-stock, an 85 might be just a bit rich if using a stock airbox, even with the second tab open. Confirm with a look at the color of your spark plug. If it's darker than cardboard, as in cocoa or black, consider an 82. A de-restricted 2001 should run a bit over 40 on stock gears.
Re: HELP!!!
i did steps as follows
1. Removed variator ramp (still stock Variator)
2. Removed washer from exhaust
3. Removed 2nd tab (plug with carrdboard because it was too much air)
4. Got 85 and 88 jets and inserted 85 in
5. Opened up the 2nd air tab again.
Sitting at about 34 on gps.
Re: HELP!!!
The title of your thread is about as bad as it gets. Put more detail into it about your problem next time
PS3 it only does everything.
Re: HELP! [EdiToaded: '01 Elite Slower After Mods]
Quoth Ryansdrawkcab:
Quoth Wheelman:
Toad's point is well-taken, if a little curt."Help!!!"
Quoth Wheelman:
Mine ran 43 without touching the engine at all. Only a Polini variator and the 90/90 tire. Didn't even cut the airbox, and the stock 78 jet still in situ. Of course it had 33 miles. Check the plug for dark color, then check compression next. If it's high-mileage, see if that pipe isn't caked with carbon.Confirm with a look at the color of your spark plug. If it's darker than cardboard, as in cocoa or black, consider an 82. A de-restricted 2001 should run a bit over 40 on stock gears.
Every recent post I have read of toads is very negative. What gives?
aerorob axt:
Jus' kiddin' Dawg, but he's right. Let's all go color-sort our sock drawers and Chillax.
aerorob axt:
OCD + Severe Paxil shortage at Walgreen's.Every recent post I have read of toads is very negative. What gives?
- Trafficjamz
He does not like the rank of "goped" and he is trying to get his post count up.aerorob wrote:Every recent post I have read of toads is very negative. What gives?
Re: HELP!!!
Wouldn't removing the ramp prevent it from ever shifting? That could be your problem right there.alridnayr wrote:i did steps as follows
Usually you would remove the restrictor plate from the back. It needs the ramp. How do you keep the rollers in without a ramp?
Re: HELP!!!
Eft37 wrote:Wouldn't removing the ramp prevent it from ever shifting? That could be your problem right there.alridnayr wrote:i did steps as follows
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
I dunno, I've made mistakes of that caliber.
Well you see I used to sleep most of the day and stay up all night but now I am trying to fix that and am not getting enough sleep and so I am a * all the time.aerorob wrote:Every recent post I have read of toads is very negative. What gives?
