AF05E crank fits an elite e and some spree cases !
Just messing around today with old parts, and made a discovery.
An AF05E Crank and bearings fits inside a sb50 (elite E) case. :surprise:
Maybe this is a useless discovery.
Or maybe this is the first step in designing a variator setup for the non-variated elite E :nerd:
Any thoughts? Questions?
martynkim
Re: AF05E crank fits an elite e case
Post by martynkim »
That could be a major discovery!
az_slynch
Post by az_slynch »
The Elite ES (Pal) was variated. From what I've read, it had a wider belt case than an Elite E. Maybe the ES used the same crank as the bigger Elite 50.
'64 Vespa 90 (V9A1)
'65 Allstate Compact (DS60)
'74 Vespa 125 Primavera (VMA2)
'81 Vespa P200E (VSX1) (2)
'83 Yamaha Riva (XC180K) (2)
'84 Yamaha Riva (CV80L)
'85 Honda Spree (NQ50)
'86 Honda Gyro S (TG50)
'87 Honda Elite (CH80)
'89 Honda Elite E (SB50P)
bradthreee
Post by bradthreee »
Nice work TJ :thumbwink:
Makes me wonder if the case of the SB50 is slightly wider than the NQ50 to compensate for the variator
Do you have Spree cases or SB50 cases?
Clivester
Post by Clivester »
Great information 'jamz
The only thing is, by the time you've bought the crank, variator assembly, suitable transmission cover, and maybe new clutch then split the engine, wouldn't it be just as easy and similar cost-wise to just buy a Dio engine and do a swap? Of course fabbing the engine mount may be an issue.............
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
bradthreee wrote:Nice work TJ :thumbwink:
I have a little of everything lying around.
I was going to give my friend, spreetard, a crank from a elite E ,for his spree.
but the elite e crank does not fit the spree case :confused: It was bigger :surprise:
That got me thinking :naughty:
I had tried to put an AF05E in a spree case before and it did not fit in the same way.
So I tried the AF05E in the elite E case..... :thumbwink: Fit like a glove.
The elite E case is slightly wider up by the front pulley, than the spree case.
Nice work - and looking forwards to all it leads to. :rock:
tazland001
Post by tazland001 »
That is true. There is a variated pal engine. They are hard to find. I would love to get my hands on one.
Taz
z50r-ghost
Post by z50r-ghost »
i 3rd the props... nice work dude; using oem Honda parts to make a "hybrid" engine is freaking killer.
looking forward to your future posts about this....
:2thumbs:
-jon
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
bradthreee
z50r-blank wrote:i 3rd the props... nice work dude; using oem Honda parts to make a "hybrid" engine is freaking killer.
:2thumbs:
-jon
I was thinking along those same lines but the word that popped in my head is "Frankenstein" motor like LS-Vtec...
az_slynch
Post by az_slynch »
bradthreee wrote:Do you have Spree cases or SB50 cases?
To follow up on that question, are you using the early or late Spree cases?
'64 Vespa 90 (V9A1)
This is a sb50 case (elite e) not a spree.
az_slynch
Post by az_slynch »
Trafficjamz wrote:This is a sb50 case (Elite e) not a spree.
I understand that your discovery came with a SB50 case. My question was directed toward what version of the Spree case were you trying to put the SB50 crank into? Word on the street is that the '86-'87 cases are bigger inside to allow for a bigger crankshaft.
'64 Vespa 90 (V9A1)
Re: AF05E crank fits an elite e and 86-87 spree case !!
Word on the street is correct!
My first try on a spree case was a 1985.
Today i tried an 86 spree case......and it fit wit no problems :surprise: :surprise: :surprise: :surprise:
Easy way to put a variator on the spree :thumbwink:
Post by eliteguy50 »
Can you still line up a starter on that spree now?
