Spree took a * need help
Posted: Thu Jul 22, 2010 1:08 pm
by CarrotTop
Motor seized up on me. Piston rings are broke.. Where can i get new rings?
2nd before they broke it had hard time staying running. What do you think caused this. Like it would start could rev it up but when it when come down and idle would die out.
Re: Spree took a * need help
Posted: Thu Jul 22, 2010 1:40 pm
by az_slynch
If you need stock rings, hit up your Honda dealer. If you need a piston and rings, try Tazland's store:
http://cgi.ebay.com/ebaymotors/Honda-Sp ... leQ5fParts
I bought one of those before, quality part. He sells rings for the RIK pistons too, but note that they do not fit the OEM Honda piston.
Posted: Thu Jul 22, 2010 4:07 pm
by toad772
Well that is completely different then what I thought the thread was gonna be about. but you can get the rings here http://www.bikebandit.com (depending on year)
Posted: Thu Jul 22, 2010 5:58 pm
by az_slynch
While I recognize BikeBandit as a good source of parts, they don't list the NQ50 (Spree) or SB50 (Elite E). Not sure which models share rings with them.
Posted: Thu Jul 22, 2010 6:06 pm
by evilone
Posted: Thu Jul 22, 2010 6:59 pm
by CarrotTop
az_slynch wrote:If you need stock rings, hit up your Honda dealer. If you need a piston and rings, try Tazland's store:
Thanks i will have to double check the head make sure it did not get Damaged and the walls when i get home.
toad772 wrote:Well that is completely different then what I thought the thread was gonna be about. but you can get the rings here http://www.bikebandit.com/(depending on year)
haha thanks!
evilone wrote:http://www.cyclepartsnation.com/pages/p ... Honda.aspx
Both models are listed.
Thanks prob just order from them seeing as few places i called would have to order them in.
Posted: Thu Jul 22, 2010 8:23 pm
by z50r-ghost
yep... i was expecting this thread to be about a different topic as well. i was really looking forward to reading it! haha! :bowrofl:
Posted: Thu Jul 22, 2010 8:43 pm
by yamahauler660r
If a spree pooped it'd probably look like deer turds! :smile: :b2t:
