why wont my gyro start?
curtis
Post by curtis »
It is a 1984. Sat for about 2 years. Has good spark. Someone removed the gas shut-off. Any ideas?
odinxxix
Re: why wont my gyro start?
Post by odinxxix »
clean the H E double hockey sticks outta the carb.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
zuphilius
Post by zuphilius »
odinxxix wrote:clean the H E double hockey sticks outta the carb.
What he said. And make sure the tank and filter are clean with fresh gas, and the oil tank and filter are clean with fresh GN2. Then when you think you have the carb clean, clean it some more. Seriously.
Then with a fresh plug, $2 at Napa, try again. Report results descriptively and we'll go from there.
curtis
Post by curtis »
Update on gyro not starting. Compression was 30#. pulled head and cylinder and found rings stuck. Removed piston and have it soaking in pb blaster. Ring set and gaskets ordered. Updates later.
