Honda Express Gremlins
Posted: Thu Jul 29, 2010 3:35 pm
have 78 Express which i am rebuilding from piece of rusted junk. i have it where it will start immediately, carry me up the block, but not back. just runs out of power, wont take throttle. i have checked compression cold, 75 lbs, and when stalled, 75 lbs. i thought it might be soft seizing or just heating up and losing compression. not the case apparently. clear gas line always appears full, so i dont think it is starving for fuel. plug burn is nice, light brown. , complete new top end - piston, rings, bearing, piston pin, honed cylinder. 1660 miles.
in a short time, it will cool off and get me back home. i am thinking that maybe some electrical gremlin is failing when hot.
it has old points and condensor magneto ignition system. Could be coil or condensor failing under heat, but thats not very
Hondalike.
any thoughts from anyone???
Hondalike.
