loose kickstand any suggestions?
- ryanmcfinney
- Goped
I just bought a new spring for my 94 elite 50 and the kickstand is still not held that tight ( the old one was missing when i bought it ). Anyone have any experience before I start trying to bend up the spring hooks? Also the kickstand pivot axle is kinda loose will tightening it help? How do you even do that?
Thanks guys
Thanks guys
- ryanmcfinney
- Goped
- sulfuraciddd
- hrnytrtlsgsxr
- lonelywanderer
I'd have to look at what you have to see what's going on. On my Spree, I had to replace the stock pin with a larger, hardened bolt and nylock nut. It had worn out to the point of rubbing on the tire.
- lonelywanderer
Slight drilling on the frame side; the stand was already stretched out to the larger size.
- lonelywanderer
