Faulty Fuel Valve
Faulty Fuel Valve
My auto-fuel valve is stuck in the open position... so there is gas in the lines even when the scooter is off. Will this affect performance? I am tuning the carb and seem to be running rich all the time.
Scooter-less
- hrnytrtlsgsxr
It *may* flood the carb and dump gas on the ground if your float shutoff quits working, but it would do that anyway. You have 3 options:
1) buy a new one, new or used
2) install a lawnmower-type manual shutoff
3) leave it alone
For #3, if you ride seasonally you should plug the carb line and drain the carb b/f storage.
3) leave it alone
Admin, Hondaspree.net
