SPREE CARB HELP!!!!!!!
biggkid2
Post by biggkid2 »
HI I HAVE A CARB FROM A SPREE THAT HAS TWO OUTLETS ON THE FRONT , NEXT TO THE IDLE AND AIR SCREWS, AND ONE SMALL ONE, I THINK ITS FOR OIL, AND AN OTHER OUTLET, I THINK ITS A VENT , ON THE BACK, AND A FUEL INLET . THIS BIKE WAS RUNNING WITH THE ORIGINAL CARB, BUT NOT REAL GREAT, SO I PUT THIS OTHER CARB ON IT, FLOAT BOWL IS FULL, BUT IM NOT GETTING FUEL TO INTAKE, I ALREADY CLEANED THE CARB, IT RUNS AWESOME IF I SPRAY SOME MIX FUEL IN THE THROAT OF THE CARB!! THEN IT DIES. I THINK THIS CARB IS FROM AN AERO? I MESSED WITH THE NEEDLE SETTINGS AND THAT DOESNT DO MUCH. WHICH OF THE OUTLETS GET PLUGGED OR CONNECTED TO EACHOTHER?? CAN SOMEONE HELP!! IN THE MEANTIME I WILL TAKE IT APART AGAIN TO MAKE SURE ITS SUPER CLEAN!! WHERE DO ALL MY LINES CONNECT TO? IT RAN WITH STOCK CARB. THANKS SO MUCH. I WILL LOOK IN TECH DOCS TO TRY TO FIND CARB ALSO. THANKS :D :D
Re: SPREE CARB HELP!!!!!!!
First, using all caps is the same as yelling on the internet.
Second, need a carb number and/or a picture of the carb.
biggkid2
Post by biggkid2 »
stock carb is a 29ccwkt, and other carb is a keihin - 34cachi , turns out stock carb has bad jet, can i still use this other one? the bystarter fits good in it also. thanks alot for the help!!!!! :coolcruise:
