Page 1 of 2
Big clutch spring
Posted: Thu Aug 26, 2010 9:23 pm
by cheydogge
Is the big clutch spring a pain to change or no?
Re: Big clutch spring
Posted: Thu Aug 26, 2010 9:28 pm
by martynkim
not really just need the correct method. use your feet to keep it compressed as you loosen it.
Posted: Thu Aug 26, 2010 9:29 pm
Li'l bit...
Posted: Thu Aug 26, 2010 9:32 pm
by cheydogge
I see the one in the pack and the one that's on the scoot and I'm scratchin my head on the size difference.Just wanna know what I'm gettin into before I tear it apart.
by Trafficjamz
yes it is a pain in the *
Put the clutch in a vise
get a huge cresent wrench
loosen the big nut
take the clutch out of the vise
step on the clutch near the sides with your feet
Spin the nut the rest of the way off
slowly take your feet off of the clutch
good luck.
I did this 3 times today. I am a pro at it. :smile:
Posted: Thu Aug 26, 2010 9:49 pm
Trafficjamz wrote:yes it is a pain in the *
loosen the big nut
good luck.
Pros don't use crescent wrench's. The use sockets and box end wrench's and if necessary open end wrench's. But crescent wrench's.............NOT!
by martynkim
loosen the big nut
good luck.
Exactly. Easy too! :thumbwink:
Posted: Thu Aug 26, 2010 10:25 pm
by cheydogge
Thanks for the info guys.I got the 9 to 1 gears I think I'll wait and do it all at once.
Posted: Thu Aug 26, 2010 10:51 pm
by Trafficjamz
What size socket fits on that nut?
The biggest I have is 36mm, and that did not fit.
I have taken several clutches apart with my trusty cresent wrench with zero problems.:smile:
But I agree a socket would be better. :thumbwink:
Posted: Thu Aug 26, 2010 11:32 pm
Manual say the special tool is a 39 X41, so I would assume it is it is 39 m or 41 mm and I would say a 39 mm. But hey someone needs to take a nut in and get a socket for it.
PS: I have sockets up to 2 5/8" and 36 mm but I will buy whatever I need to do the job right. Oh and yes I do have crescent wrenches, a 4", 6" (2), 8", 10", 12" and 16", but I use them as hammers more often than as wrenches
Posted: Thu Aug 26, 2010 11:37 pm
by Trafficjamz
Well then I will buy a 39mm socket tomorrow, so I can maintain my "Pro" status. :smile:
Posted: Thu Aug 26, 2010 11:50 pm
by z50r-ghost
Then I guess I'm 1-up in "pro" status from the sockets; I bought a set of Polini wrenches (2 wrenches; 2 different sizes on each side) specifically for removing all the common Japanese / Italian / Spanish sizes of clutch-contra spring large nuts. :thumbwink:
The wrenches are HUGE to easily get torque going on, and removing.
-jc :coolcruise:
Posted: Fri Aug 27, 2010 12:03 am
by Trafficjamz
z50r-blank wrote:Then I guess I'm 1-up in "pro" status from the sockets; I bought a set of Polini wrenches (2 wrenches; 2 different sizes on each side) specifically for removing all the common Japanese / Italian / Spanish sizes of clutch-contra spring large nuts. :thumbwink:
-jc :coolcruise:
:worship: :worship:
Pros use HUGE TOOLS
Posted: Fri Aug 27, 2010 12:06 am
Since I haven't done a clutch yet and I don't have a 39 or 41 mm unless one my SAE sockets will work. Let's see a 39 mm = 1.54", then a 41 mm = 1.61".
My uncle was a Caterpillar mechanic, he had sockets up to like 4".
Posted: Fri Aug 27, 2010 12:13 am
by toad772
-jc :coolcruise:
:worship: :worship:
Pros use HUGE TOOLS
Well then I guess I am a pro I have some pretty huge wrenches much bigger then that little nut.
