1984 Honda Gyro Air screw settings? Also some pics...
Posted: Fri Aug 27, 2010 12:51 am
by bradthreee
What should the settings be on both the idle and air/fuel screws on the carb?
Is it the same for an 85-86?
Here are some pics of my newly aquired Gyro:
Re: 1984 Honda Gyro Air screw settings? Also some pics...
Posted: Fri Aug 27, 2010 2:07 am
by sanjuro
Geez I want one of those so bad.
Posted: Fri Aug 27, 2010 3:24 am
by zuphilius
Nice!! Looks familiar!!
I think the stock airscrew on a '84 is 2 turns out.
You got the manual?
It's here: http://www.boogerballs.com/GYROs.htm
Posted: Fri Aug 27, 2010 10:22 am
Hey - good find, That Gyro looks great.
zuphilius - thanks for the manual link.
Posted: Fri Aug 27, 2010 10:26 am
by bradthreee
Thanks for the manual links!
That is exactly what I neeed :geekdance:
Posted: Sun Sep 18, 2011 11:43 am
by Jayspence7
Any chance you know the size of the screw/spring? Just got an NN50 1984 Honda Gyro with only 1k miles but the old man lost the screw the last time he was doing maint.
Thank you thank you! =]
Posted: Sun Sep 18, 2011 12:21 pm
1k miles - good find!
Can't give you a size/spring. It's a tapered brass needle valve, easiest is to drop in a Honda part.
16016-197-004 SCREW SET $11.91
Part is common to Spree, 83-87 Aero50, Elite SE50 and Gyro TG50 85-86. Post a "Wanted" in the Wanted/For Sale area if you like, someone may have a used set for a little less.
Posted: Thu May 10, 2012 7:32 pm
by wasilly
sanjuro wrote:Geez I want one of those so bad.
I've got a red gyro, 400 miles on speedometer. runs good. wasilly
