Runs with throttle but wont Idle
Posted: Sun Aug 29, 2010 12:00 pm
by crime_spree
Hey guys,
I got an 86 Spree...Any idea what could be causing it to die when I stop giving throttle? It runs perfectly 30-35 mph until I stop, then it dies and will start again upon a few kicks.
I've read a few threads involving air, carb, etc. figured I'd ask and see if it can be pin pointed..
Thanks for the help
Re: Runs with throttle but wont Idle
Posted: Sun Aug 29, 2010 12:53 pm
Idle circuit in carb is at least partially plugged up.
Posted: Sun Aug 29, 2010 1:14 pm
by fastplastic
just do a good clean job on the carb and see if that helps :thumbwink:
Posted: Sun Aug 29, 2010 1:19 pm
Check the float level carefully when you are in the carb.
Posted: Sun Aug 29, 2010 1:28 pm
by fastplastic
Bear45-70 wrote:Check the float level carefully when you are in the carb.
thats gotta be what it is i think you hit the nail on the head
