Average stock speed for a spree
Mike
Post by Mike »
mine goes about 24mph without an airfilter temporarily...is this about right?
scootngo
Post by scootngo »
Sounds a tad low. I've read 30mph for non-Iowa model.
Mine tops out at about 28mph indicated.
Mike
Post by Mike »
well do you think having a rag as an air filter would make that bid of a difference?
Streetglow
Post by Streetglow »
mine does 35mph on straight level ground.. 40 with a tailwind! totally stock
86 Spree (w/neon)
Mike
Post by Mike »
wow, well i pretty sure i need new compression rings so that could be a possibility too.IM JEAULOUS NOW! hahah
darat
Post by darat »
i can wip all of ur asses lol with the elite. beside the guys whith the d*** dios.
JF
Post by JF »
Not to be rude, but a rag defiantly wouldn't be my first option for an air cleaner. If the filter/air box somehow gets really screwed up while I'm out driving and I'm about to go through a freak sand storm, then yea I might consider it(more like consider pushing the bike :lol: ) Is there something wrong with the air box or the air filter foam? If so, then you might want to consider getting an after-market air cleaner. But if the box and the foam are in good shape, then you should clean/re-oil the filter, and reconnect the air box tube to the carb. That way, it'll be easier to find out why your spree isn't up to speed. Let us know your observations.
JF
1978 Puch Free Spirit, a 1980 Honda NC50, a 1985 Honda Spree, and a 2005 Yamaha Zuma. Gotta love two-stroke power...:)
Mike
Post by Mike »
o i know, no offence taken, i only have the rag because i am waiting on my stock filter from the dealership. today is the fifth business day so i should be getting it :wink:
86elitespree
Post by 86elitespree »
Down hill? 33mph but level riding? LOL lets just say i am just happy its moving forward.
burnt_toast
Post by burnt_toast »
darat wrote:i can wip all of ur asses lol with the elite. beside the guys whith the d... dios.
ahem ahem. all of us ay?
even this here 90cc vento? 8) Cruise speed of 50-53mph, top 58mph. :D Mainly tuned and ported for torque.
As far as the spree, 25mph is about right w/ a slight incline. Should go about 30mph on a flat and 35mph is the sweet spot down a hill.
projects galore :nerd:
darat
Post by darat »
ok lets put this in my words any thing that is over 50cc
Mike
AHH!
Post by Mike »
okay, i just put in the new air filter... but now when i give it gas it bogs out... i adjusted the idle speed screw to the point just before the wheel starts to spin. i have the oil/fuel mixture screw at about 1 7/8, so i dont know whats wrong...does it need more air flow? i am stumped.... because it ran fine with the rag over the carb with a hole in it...HELP A "BROTHER" OUT! hahah
burnt_toast
Re: AHH!
Mike wrote:okay, i just put in the new air filter... but now when i give it gas it bogs out... i adjusted the idle speed screw to the point just before the wheel starts to spin. i have the oil/fuel mixture screw at about 1 7/8, so i dont know whats wrong...does it need more air flow? i am stumped.... because it ran fine with the rag over the carb with a hole in it...HELP A "BROTHER" OUT! hahah
make sure that the airbox isnt letting air get in anywhere else besides the intake tract. Usually the pegs holding it on tend to break, easy fix is to just duct tape all around till the holes are covered.
It's bogging out due to too much air, aka vacuuming. Check airbox and close up as necessary and you should be good to go! :)
