Gaskets
Re: Gaskets
They sell entire gasket kits for several different elite engines. Did you have a specific engine in mind? Like a 1989 elite S (sa50p) for example.
Re: Gaskets
Mine is a 99 eliteS sa50 I'm gonna put a crank and bore kit.eliteguy50 wrote:They sell entire gasket kits for several different elite engines. Did you have a specific engine in mind? Like a 1989 elite S (sa50p) for example.
Re: Gaskets
HondaBond is what they use for the main case union. You should get a cylinder head and base gasket with your BBK but you typically have to buy your own exhaust gasket.
You can search ebay for a gasket set and get a few options. Honda sells a gasket kit (Honda code: 6379440) but I don't know what all gaskets that includes.
Re: Gaskets
Cool I was wandering if there was a gasket when you split the case.
Re: Gaskets
Honda didn't do that in the 1994-2001 motors. The other motors do have a gasket there.cheydogge wrote:Cool I was wandering if there was a gasket when you split the case.
- tazland001
Re: Gaskets
I use Yamabond. that s*** has never let me down. A very good product.
Taz
Taz
