high compression headswap jetting?
shane_lxi
Post by shane_lxi »
I was reading in the wiki about swapping the head off an 84-85 spree onto a later model for a bit higher compression. I have an 84 parts bike, so I'm thinking of giving this a shot. What size jet would be recomended for this swap? Thinking of maybe shaving around .010 off also.
'86 spree; '87 cressida; '89 240sx
Re: high compression headswap jetting?
Not really sure you need to upjet.
Do run premium fuel if compression goes past 140psi
I agree with TJ. Jetting should not be an issue.
shane_lxi
Post by shane_lxi »
Thanks for the help guys! It definately check compression once the head goes on. I'll update this thread if this ends up working out!
shane_lxi wrote:Thanks for the help guys! It definately check compression once the head goes on. I'll update this thread if this ends up working out!
Oh it works alright :thumbwink:
I don't think you have to shave .010 off of the head though :confused:
I was under the impression that you shaved the '86-'87 head .020" and just swapped on the '84-'85 head. no shaving required.
shane_lxi
Post by shane_lxi »
Awesome, even better if I dont have to take a trip to the machine shop. Thanks alot guys! Ordered my headgasket today, so as soon as that get's here, I'll pop the '84 head on there and try it out :D. I love freebies!
shane_lxi wrote:Awesome, even better if I dont have to take a trip to the machine shop. Thanks alot guys! Ordered my headgasket today, so as soon as that get's here, I'll pop the '84 head on there and try it out :D. I love freebies!
My friends 1987 spree had a compression reading of 125psi.
Swapped to a 1985 head and the reading was 150psi :surprise:
shane_lxi
Post by shane_lxi »
Any problems with rings or anything after the swap? That's a pretty big jump in compression.
shane_lxi wrote:Any problems with rings or anything after the swap? That's a pretty big jump in compression.
Belt and clutch slippage from the newly added power was the only issue.
shane_lxi
Post by shane_lxi »
That much more power gain eh? I put ax24 vbelts in our bikes today, and lost 2mph off the topend for some reason, so I put our stock belts back in. Sooo, if I slip, I'll try and get a new oem belt. I don't think my clutch will slip @1200miles, but who knows til I'm there :D.
ps: ax24's are supposed to be 1/2"x24" right? My Gates ax24's are 1/2"x26", not sure if maybe that's the cause of power loss or not?
shane_lxi wrote:That much more power gain eh? I put ax24 vbelts in our bikes today, and lost 2mph off the topend for some reason, so I put our stock belts back in. Sooo, if I slip, I'll try and get a new oem belt. I don't think my clutch will slip @1200miles, but who knows til I'm there :D.
Did you measure the inside or the outside?
shane_lxi
Post by shane_lxi »
I didn't measure, package was labeled 26", prolly outside, but it is noticably bigger diameter than stock.
The stock Spree belt is 24.7244" X 0.4488", so a 26" belt is only 1 1/4" bigger for the pulley mod.
spewya
Post by spewya »
i have a sb50p and if i do pully mod by putting a se50p clutch in it and cutting the case will i need a longer belt and how much do i mill down the front inner pully
Bear45-70 wrote:The stock Spree belt is 24.7244" X 0.4488", so a 26" belt is only 1 1/4" bigger for the pulley mod.
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
