78cc nicasil bore
tospreeornottospree
78cc nicasil bore
Post by tospreeornottospree »
since my 82cc tawinese bore is trashed i decided to go with the aluminum 49mm 78cc nicasil bore thoughts on it and opinions!
maddog
Re: 78cc nicasil bore
Post by maddog »
i was told they don't last long- 5,000 mi. but reliable.
maddog wrote:i was told they don't last long- 5,000 mi. but reliable.
That would be about 10x longer than your 82cc :smile:
tospreeornottospree
lol right see what happens next
maddog
Post by maddog »
GO FOR IT :smile:
Post by eliteguy50 »
tospreeornottospree wrote:since my 82cc tawinese bore is trashed i decided to go with the aluminum 49mm 78cc nicasil bore thoughts on it and opinions!
Did you prep your Taiwanese bore? I don't think you have to prep the KJT Nikasil bore, it is a true bolt on.
What do you mean "prep" the bore?
Clean it up. It may fit well enough to bolt right on but most of the Taiwan kits need the installer to check for burs and clean up any casting material on the flange. Chamfer the ports.
It was a wrist pin clip that came loose that killed the Taiwan bore :sad:
The bore was cleaned up
Trafficjamz wrote:It was a wrist pin clip that came loose that killed the Taiwan bore :sad:
Oh, time to ceramic coat the next one.
