78cc nicasil bore
Posted: Thu Sep 09, 2010 10:02 pm
since my 82cc tawinese bore is trashed i decided to go with the aluminum 49mm 78cc nicasil bore thoughts on it and opinions!
Keeping Spree Elite Aero 50cc and Gyro Alive!
http://hondaspree.net/hondaspree.net/phpBB3/
http://hondaspree.net/hondaspree.net/phpBB3/viewtopic.php?t=16345
That would be about 10x longer than your 82ccmaddog wrote:i was told they don't last long- 5,000 mi. but reliable.
Did you prep your Taiwanese bore? I don't think you have to prep the KJT Nikasil bore, it is a true bolt on.tospreeornottospree wrote:since my 82cc tawinese bore is trashed i decided to go with the aluminum 49mm 78cc nicasil bore thoughts on it and opinions!
What do you mean "prep" the bore?eliteguy50 wrote:Did you prep your Taiwanese bore? I don't think you have to prep the KJT Nikasil bore, it is a true bolt on.tospreeornottospree wrote:since my 82cc tawinese bore is trashed i decided to go with the aluminum 49mm 78cc nicasil bore thoughts on it and opinions!
Clean it up. It may fit well enough to bolt right on but most of the Taiwan kits need the installer to check for burs and clean up any casting material on the flange. Chamfer the ports.Trafficjamz wrote:What do you mean "prep" the bore?eliteguy50 wrote:Did you prep your Taiwanese bore? I don't think you have to prep the KJT Nikasil bore, it is a true bolt on.tospreeornottospree wrote:since my 82cc tawinese bore is trashed i decided to go with the aluminum 49mm 78cc nicasil bore thoughts on it and opinions!
Oh, time to ceramic coat the next one.Trafficjamz wrote:It was a wrist pin clip that came loose that killed the Taiwan bore![]()
The bore was cleaned up
