1st scooter build
gman
1st scooter build
Post by gman »
picked up a clean 87 spree with 600 miles, for 15year old daughter, she complained it wasn't fast enough. was planning a big bore kit for winter project. wife and neighbor kid went for ride, wife has 85 150 elite deluxe. i got the call that the spree quit running. brought home, took jug off and piston skirt broken off. so, winter project became summer project. 48mm big bore kit with gears installed, with all new bearings, seals, gaskets, elite intake, reeds, uni filter, oil pump plug, 275-10 bridgestones. thanks to this forum for the plan. just finished the motor and it runs great. now to install the panels and see if it hits 40-45 mph!!!
87 Spree
85 Elite 150 Deluxe
02 XR650R
Re: 1st scooter build
It will be quick.....but it won't go 45mph.
Taz gears do not increase the top speed by 15mph :surprise:
2.75 bridgestones and taz gears will go 35-38mph tops
SPREEtown
Post by SPREEtown »
hmm what happened to this guy? if he didnt hit 45 maybe he hit a car :eyeroll:
but where do you get an oil pump plug for an nq50? vt says their sa50 plug will not fit a spree
1986 Spree SE:
  • pulley mod
    '85 head
    SB50 intake, reeds, carb
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
    taz gears, sa50 clutch w/ 2k springs
Spreetard
Post by Spreetard »
You grind the gears off the shaft that drives the oil pump.Completly off. Then re-install the whole assembly.
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
SPREEtown
Post by SPREEtown »
really i have to take a grinder to honda-san's hard work? there's no after-market plug that will fit? besides one made of pocket change...
1986 Spree SE:
  • pulley mod
    '85 head
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
gman
Post by gman »
SPREEtown wrote:hmm what happened to this guy? if he didnt hit 45 maybe he hit a car :eyeroll:
got busy with work, hit 40mph with kid on it, still with 1st tank of gas. runs and sounds great. i will try and send some pics.
honda spree.jpeg (231.53 KiB) Viewed 6870 times
87 Spree
85 Elite 150 Deluxe
02 XR650R
Where did you get that oil pump plug for the nq50 again?
Hit 40mph on the spreedometer maybe :smile:
Spreetard hit 50mph using the very inaccurate Spreedometer :eyeroll:
Nice '87. How about more pics?
gman
Post by gman »
Trafficjamz wrote:Where did you get that oil pump plug for the nq50 again?
oil plug is coin made, i am 265lbs and hit 33 mph on garmin gps
honda spree.jpg (7.78 KiB) Viewed 6831 times
87 Spree
85 Elite 150 Deluxe
02 XR650R
ae86guy
Post by ae86guy »
i had one machined up to fit my spree
ae86guy wrote:i had one machined up to fit my spree
That is awesome. :2thumbs:
