engine turns over no spark
Posted: Tue Sep 14, 2010 10:58 pm
by biggkid2
i have a 86 spree i put together from a few different sprees- no spark, question can i check the charging coil or pickup coil for resistance, if i put a continuity tester in the coil wire(plug wire) it lights up. i hve a charged battery, engage brake handle,have switch in run position, and - no spark. what should i test in the starting circuit and how. the harness looks good. thanks for helping the new guy!!!
0
Re: engine turns over no spark
Posted: Tue Sep 14, 2010 11:05 pm
Posted: Wed Sep 15, 2010 11:42 am
by axo
That is the "owners manual"... not a "Service" one... the only electrical section is about checking the fuse.
I read on another thread a user posted useful information which actually described the procedure on checking the coils and everything... i will try to find it
Posted: Wed Sep 15, 2010 12:18 pm
Oops,
http://www.hondaspree.net/other/Spree_NQ50_84-87_1.pdf
If everyone read the titles to all the differnet forums on the Hondaspree.net they would find this and all the manual needs would be taken care of.
http://www.hondaspree.net/phpBB3/viewforum.php?f=11
Posted: Thu Sep 16, 2010 12:31 am
by veedubh20
spree had bad cdi that why motor will not run. Just change cdi and motor will run. No mind the book!
