Page 1 of 2
Custom Pistons for mopeds
Posted: Fri Sep 17, 2010 2:19 am
by Trafficjamz
Re: Custom Pistons for mopeds
Posted: Fri Sep 17, 2010 2:33 am
Lighter pistons will require a balance job, but the thing that I would be more worried about is wrist pin or compression height. Just because a piston is the same diameter does not mean the wrist pin is the same distance from the top of the piston.
Posted: Fri Sep 17, 2010 2:40 am
by Trafficjamz
Bear45-70 wrote:Lighter pistons will require a balance job, but the thing that I would be more worried about is wrist pin or compression height. Just because a piston is the same diameter does not mean the wrist pin is the same distance from the top of the piston.
Oh yeah, I know that the bore size is not the only spec to be concerned with.
What has to be balanced to go with a lighter piston?
Posted: Fri Sep 17, 2010 2:53 am
I would assume (I know it is a bad thing) that the purpose of the lighter piston is to rev the motor quicker and higher. To make that happen and retain some reliability you should balance the motor. With my super stock motor we were not originally allowed to grind on the rotating assembly parts. The last 2 years I race in the Super Stock class we were allowed to balance since the motors were now out of production. My motor went from a max RPM of 7400 to 7600 with only the balancing. Maybe it was my imagination but the motor felt smoother too.
Posted: Fri Sep 17, 2010 3:09 am
by Trafficjamz
I understand in a multi piston setup, that the pistons need to weigh the same.
But what is there to balance in a single piston setup. :confused:
Posted: Fri Sep 17, 2010 5:00 am
by bakaracer
you can get ahold of wiseco and give them the specs you need. they can make a piston for you if you need
Posted: Fri Sep 17, 2010 6:24 pm
by toad772
Crankshaft.
Posted: Fri Sep 17, 2010 7:33 pm
by Trafficjamz
toad772 wrote:
Crankshaft.
:confused: Why would I need to balance the crankshaft if I change the piston? Isn't it already balanced :confused:
Posted: Fri Sep 17, 2010 8:23 pm
by bakaracer
its really hard to balance a single piston 2 stroke crank
Posted: Fri Sep 17, 2010 9:08 pm
bakaracer wrote:its really hard to balance a single piston 2 stroke crank
And that ia exactly why it is so important.
Posted: Fri Sep 17, 2010 9:28 pm
by Trafficjamz
I still dont understand. :confused:
What needs to be done to the crank , if a different weight piston is used?
Posted: Fri Sep 17, 2010 10:52 pm
When you rev the engine faster and higher, any small imbalances are multiplied for every 100 RPM you add to the top end. Anyone doing it RIGHT is gonna balance the rotating assembly. It improves performance and longevity.
Posted: Sat Sep 18, 2010 1:26 am
by nickisaninja
The counterweight on a crank needs to offset the weight of the connecting rod and piston.
If there is an imbalance say, 1gram, that gram gets multiplied exponentially with speed.
Say the piston weighed 1gram more than the counterweight. Every time the piston would be on it's downstroke the imbalance would push the crank into the case with more and more force coinciding with engine rpms. Every compression the piston would pull on the crank because the counterweight would not be able to cancel out the piston+rod+wristpin+retainingclips weight, since the counterweight is supposed to neutralize the weight of the rod and piston acting against the crank.
That's the best I can come up with. Make sense?
Posted: Sat Sep 18, 2010 11:14 am
by Epschoenly
http://www.treatland.tv/vertex-47mm-tef ... piston.htm
Moped racers are using these. Food for thought.
Posted: Sat Sep 18, 2010 11:49 am
by Trafficjamz
nickisaninja wrote:The counterweight on a crank needs to offset the weight of the connecting rod and piston.
That does make sense......thanks.
