Fixing Plastic
Fixing Plastic
Just got another 1985 Honda Gyro and some of the plastic is cracked .
I have a plastic welder but the crack lines up pretty good , And was wondering if anyone has some trick ways of repairing it , Im thinking a good glue (not super glue ) might do the job ? Has anyone got any great glue suggestions or other ways to repair and ??? sand the plastic . I would like all input and think this could be helpfull to a lot of the members .
top right side crack
turtle13
Re: Fixing Plastic
Post by turtle13 »
i havent found anything other than melting it back together that works with that type of plastic. that panel is made of the same plastic that the inner leg shield and rear fenders are mad out of right? if its ABS you can use some scraps of abs and some MEK, and make a glue/filler with it that works great. just use fiberglass mat as a backer to give it some strength.
'62 125cc Honda cub
dogmir
Re: Fixing Plastic
Post by dogmir »
In a situation like that I would just use MEK and abs pieces to chemically weld it. Abs cement for plumbing would work too. In a pinch you could use this:
http://www.permatex.com/products/automo ... c_Weld.htm
It is a Methyl based acid that gives you chemical and mechanical bond. Just make sure to take a dremel on the backside of the crack make a v-shaped groove. This will make a channel, and then fill that in. I would use the aluminum tape used for heating ducts on the front of the crack to keep the pieces together.
Clivester
Re: Fixing Plastic
Post by Clivester »
Like Turtle, I think that piece is polypropylene rather than ABS. In that case the MEK will not work and plastic welding would be your best bet.
1986 Yamaha XC180 Riva
1985 Honda CH150D Elite
1988 Honda SA50 LX Elite
1989 Honda SB50
2007 iScooter 150cc
2006 Roketa 150cc
2006 TNG Venice 50cc
axo
Re: Fixing Plastic
Post by axo »
Be ghetto
Drill holes and sew it using plastic tie wraps. Make sure to combine different colors to add more pimp factor.
1989 Honda Dio SP
AF18E - 82cc Taiwan kit - 24mm Oko - KRS pulley kit - Kevlar belt - 8.44:1 gears - 1000RPM Center spring - 7 grams roller weights - R1 sectional exhaust - 130lb pilot :)
turtle13
Re: Fixing Plastic
Post by turtle13 »
if you are unsure of what type of plastic it is made of, look at the end where it is broken and see if it is the same color all the way through. if it is not, and it is white in the middle it is ABS. if it is solid black all the way through it is definitely poly.
'62 125cc Honda cub
Re: Fixing Plastic
I actualy have some MEK and might do some exparments .I will give it a shot Thanks.
Re: Fixing Plastic
Dogmir your a good salesman .Its too late tonight but tomorrow I will be off to Lowes to get the Permex stuff I looked at the link and it sounds perfect . Thanks !
Re: Fixing Plastic
You had me going for about 3 millaseconds . But I knew you were kidding who would use zip ties ? There expensive .
