circlips and base gasket
trains420
Post by trains420 »
what's the best way to put circlips in? i found out by looking. bear said get a pair of needle nose pliers and put a notch in them. i done that and was able to hold onto it.
another question. the base gasket, it's not lining up around all the ports on the bottom of the cylinder. should i just cut it out? it's going to be off. will that be ok? the inside of the ports has a line of metal, and gaskets don't have that with a gasket around it. is it going to be fine, with the no gasket around the ports? i'll get a picture.
left here, is how it looks when i put it on, the right, i've used a knife and sander on it.
left not cut, right cut
Picture 092.jpg (125.48 KiB) Viewed 2985 times
here's closer of the right, with the edges around it. see the inside metal, no gasket, and no gasket has that.
closer port
closer port
Picture 093.jpg (151.85 KiB) Viewed 2984 times
toad772
Re: circlips and base gasket
Post by toad772 »
I put the circlips in by hand.
PS3 it only does everything.
z50r-ghost
Post by z50r-ghost »
Also be sure to stuff a clean into the crankcase around the piston in case the circlip gets dropped... splittng a block to assure that the circlip did not fall into the crankcase is not fun!
jon
>< Solitaire Unraveling ><
...my life story
1990HONDANS50F
