Using Royal Purple oil
- 85spreeelite
When I started moding my elite out I dumped the oil 2 cycle oil and put 5w30 Royal Purple in it and it ran smoother then it did that 2 cycle oil in it. Has anyone else on here used this? I knew that it worked wonders in my cars but I was taking a gamble with the scooter but it paid off in the end.
The ONLY thing I hate about Royal Purple is the price. Being $10+ a quart when i own a classic chevy with a v8 and 2 other rides with v6 engines. For me? Buying the oil is the problem not changing it, but at this point I wouldnt use anything else.
- 85spreeelite
Darat? bad how? Can you explain? I mean The reasons I use it in my classic and my new cars is because the classic has a newly rebuilt 283 and I use it in my malibu and the van but both of those cars had under 15000 miles each, and at the time my 94 elite only had 1100 miles on it.
How about this?
What if I were to mix half and half? Would it still be bad for the engine?
How about this?
- 85spreeelite
- 85spreeelite
- 85spreeelite
I use Royal Purple Two cycle oil all the time in my peds. That is some good stuff. And it has saved my engines countless times in "high-stress" situations, so I'd say it's good oil. One thing I found out the hard way though; NEVER use RP or any other synthetic oil when breaking in an engine; The rings will not set properly, and it will probably soft seize on you. I had that happen after I had ridden down a large hill, and had to push it a few miles back to the house; NOT FUN. But anyway, I would highly recommend this oil for a stock or upgraded engine, and don't forget to try some 10w-30 RP in the transmission case.
JF
JF
1978 Puch Free Spirit, a 1980 Honda NC50, a 1985 Honda Spree, and a 2005 Yamaha Zuma. Gotta love two-stroke power...
Royal purple
http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEWA%3AIT
Here's a good buy on the royal purple. Cheapest I've found yet!
For online, that looks to be a good buy, but if you factor in shipping costs, it comes to $13.89. Not bad, but you might get out a little cheaper checking out the local motorcross/hardware store first. I get my RP oil from NAPA for around 8 bucks, so it might not be a bad idea to log on to Royal Purple's site, and use their "consumer products" store search function to find someone in your state that sells Royal Purple products. It may be cheaper, but if it isn't, then what Greg posted might be your best bet.
JF
JF
