CL Find. Should I get?
Posted: Sun Oct 03, 2010 4:42 pm
by catsailor
http://providence.craigslist.org/mcy/1986706688.html
I am going to look at this tomorrow morning. Owner says that it has lost compression. Up to now I have only thought about the spree. Can anyone tell me about this one? Seems like a good deal. Front fender is cracked but otherwise all plastics are in tact. Seems like it might be a good winter project.
Re: CL Find. Should I get?
Posted: Sun Oct 03, 2010 4:44 pm
by martynkim
Man, jump on that!!! a white one and $50! you can't lose!
Posted: Sun Oct 03, 2010 4:46 pm
by odinxxix
Posted: Sun Oct 03, 2010 5:02 pm
by catsailor
Is it easy to get parts for the Aero 80 motor? Upgrades? Would imagine if it has low compression, i would have to do rings at the least, or a whole top end rebuild. Does Taz have a kit for this? He also said that the door for the tool compartment was missing. Is that like the dreaded petcock cover on the spree? hard to find?
Posted: Sun Oct 03, 2010 6:00 pm
by martynkim
Its a 50 not an 80 has the variated AFO5E Engine. Parts are pretty easy to find. VT sells a BBK for it or malossi or even a used OEM bore and piston. (I have an extra)
Posted: Sun Oct 03, 2010 6:20 pm
by MrGoodwreck
I would not wait till morning...
Posted: Sun Oct 03, 2010 7:13 pm
by martynkim
He also said that the door for the tool compartment was missing. Is that like the dreaded petcock cover on the spree? hard to find?[/quote]
Not too hard to find. Maybe hard in white but the other colors no problem.
Posted: Sun Oct 03, 2010 10:00 pm
by eliteguy50
catsailor wrote:Is it easy to get parts for the Aero 80 motor? Upgrades? Would imagine if it has low compression, i would have to do rings at the least, or a whole top end rebuild. Does Taz have a kit for this? He also said that the door for the tool compartment was missing. Is that like the dreaded petcock cover on the spree? hard to find?
Taz does not offer a bore kit for the nh80 but for this 86/87 nh50, he offers a 44mm BBK.
Posted: Sun Oct 03, 2010 10:11 pm
Well, it is not an 80 because the kick starter is facing aft. On the 80 in is forward,
