spree carb questions: tuning 44mm BBK
SPREEtown
Post by SPREEtown »
set up is in sig. i am running nq50 intake and carb w/ sb50 reeds. well oiled uni filter. 44mm bbk. bpr 7hs plug. premix 32:1 + oil pump. 95 main jet.
so my spree is running strange. will not run w/ out air screw seated and idle screw seems to only have 3 setting: super fast idle, very weak idle, or no idle. nothing in between. and she runs great w/out the idle screw installed but will not idle. i'm still breaking in so i havnt gone above half-ish throttle but she runs like a top.
bystarter?
1986 Spree SE:
  • pulley mod
    '85 head
    SB50 intake, reeds, carb
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
    taz gears, sa50 clutch w/ 2k springs
fastplastic
Re: spree carb questions: tuning 44mm BBK
Post by fastplastic »
main jet is a little big but if you do a plug chop and its white ish vacuum leak for sure but with it bogging on the bottom and reving out on the top its probably too rich, my kit has extensive porting and i have a 90 jet and my plugs come out perfect...
SPREEtown
Post by SPREEtown »
my mistake. its actually a 95 main jet. im fine with a little rich on break in. have not taken her above half throttle so i dont know what WOT feels like. vac leak is possible, but very improbable. the reason i suggested the bystarter is because it seems to "calm down" after warming up.
1986 Spree SE:
  • pulley mod
    '85 head
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
fastplastic
bikeman32 wrote:
SPREEtown wrote:premix 32:1 + oil pump.
im going to say on your tuning carb question, too much oil.
ok done, topics answered. unless he messed up something. and why wouldn't i get it. well, pour some gas i nyour engine.
wow... 3 posts and you think you own the place p.s. you have an air leak spreetown thats why you cant control it though your carb........
SPREEtown
Post by SPREEtown »
yeah air leak makes sense to me. i got a new petcock and mounting nut is less than optimal. i'll switch back to the old one and see if that doesnt solve anything.
thanks
or maybe ill throw some more gas in the tank. :wink:
1986 Spree SE:
  • pulley mod
    '85 head
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
fastplastic
my breakin mixture was roughly 24to1 and now run 32to1 for daily riding oil is not your problem bike man is clueless sorry dude but you are....... :crazy:
fastplastic
more oil does lean fuel mixture but also allows better lubercation which makes it ideal for breakin periods and he does have his setup rich to begin with so his oil mixture is fine, the fact that you have no experience with this subject makes all of your postings invalid so get off it... :2thumbs:
bikeman32 wrote:i thouhgt youd break in at 32:1. guess ive never done a break in. get over yourself. or maybe, break in at 40:1. what an oily fuel.
Your lack of knowledge of 2 strokes is apparently vast. You never break-in with less oil than you plan on running, EVER!
fastplastic
thank you bear once again to the point and correct :thumbwink:
bikeman32 wrote:never pointed out i was pro, but i did point out his oil is rich. and i also pointed out i wasnt pro, then i never heard of past 32:1 oil mixture, except a long time ago.
I remember when 25 to 1 as the standard, back in the bad old days, I mean everyone used it and I have personnally run as much as 18 to 1 myself in special circumstances.
SPREEtown
Post by SPREEtown »
the petcock was not the problem. i also tried a different by-starter for kicks
Sprayed WD-40 all around looking for a leak, but couldnt spike the rpm.
and now it seems worse: i have essentially no control over idle. so a LOT of air is getting in somewhere.
new exhaust gasket, top end gaskets, intake gaskets, hoses are very snug. has vacuum. good compression. uni is on tight.
1986 Spree SE:
  • pulley mod
    '85 head
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
fastplastic
if you can spray along the case, you could have a case leak, try case and bore and bore and head as well and im not sure about wd40 never tried that before but if you have had sucess go with it
evilone
Post by evilone »
bikeman32 is also known as trains420. The name change didn't work trains420! Enough said.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
SPREEtown
Post by SPREEtown »
fastplastic wrote:if you can spray along the case, you could have a case leak, try case and bore and bore and head as well and im not sure about wd40 never tried that before but if you have had sucess go with it
have you used something else or have a different method? i think i read bear used this method in some post...
ill check the head, case, and bore seals. the seal might expand a bit after running and this may be why it seems to calm down when it warms up..
:? f*** this bike........
1986 Spree SE:
  • pulley mod
    '85 head
    UNI filter
    44mm bbk
    3x10 conti zipps
    next:
WD40 itself is not flamable but the propellant it uses is and will cause the motor to rev up. You can always use stating fluid (ether) if you prefer.
