2002 Elite 80 odd running problem
Posted: Tue Oct 12, 2010 7:41 pm
by 95talontsi
So Im working on this 2002 elite 80 for this lady to see if i can get it running for her, Its been sitting a year, guessing i should just take the carb off and clean it but before i do that heres something i notice, I was messing with it, and dont know why i did it but I did. I put my finger in the carb inlet and cranked it over and it fired up and idles as long as my finger is restricting air. So im thinking its either getting to much air, or not enough fuel. Cause by cutting airflow its making the mixture correct im thinking.
whats some opinions thanks.
Re: 2002 Elite 80 odd running problem
Posted: Tue Oct 12, 2010 7:47 pm
The carb may have a clogged low-speed circuit, delivering insufficient fuel for it to run with full air. Blocking the throat with your finger acts as a true "choke" and forces higher vacuum to occur, perhaps sucking fuel from the Main or any other handy passages. It might run at idle or a bit more with a throat so restricted, but probably won't produce much power at much higher RPM with the limited access to O2. Plus, you may need that finger back. :)
You had the right idea in cleaning the carb.
Posted: Tue Oct 12, 2010 8:55 pm
by SPREEtown
i have an SB50 carb that acts the same way. but that baby is so fresh and so so clean. i can't get a drop of fuel in bowl with out choking it by covering the air inlet. i tried a new bowl gasket, a known good needle, and resurfacing the needle valve seat. could it be an extremely stubborn blockage?
Posted: Fri Oct 15, 2010 11:22 am
by 95talontsi
Im going back over there tonight, so ill go ahead and pop the carb off and give it a good once over. thanks for the help
