spree wont shut off!
MySpree
Post by MySpree »
well as you people know i am the owner of a spree with specilly made hp parts that allow me to go 40-45. well latly i have been encountering my engine not suntting off when the kill swich is turned. or when the key is pulled out. it just keeps running until i let go of the trottle rev it a couple time so it goes to and idle. adn then once i compleatly stop it will die after 1 more rev. whats the problem i alredy put in a new harness kill swich and ignition. why is it doing this to me!!!
darat
Post by darat »
not running high enough octane in the gas. that's what happends when a high compression car runs on low octane it wont shut off.
vette76
Post by vette76 »
or... you can check spark with the switches turned off. if it has spark then its a wiring problem.
87' spree (SOLD
12' wrx
MySpree
Post by MySpree »
checked spark when the run swich is flipped. there is non. nor when the key is out.
darat
Post by darat »
U got one * up moped thats all
fizzle
Post by fizzle »
could it be that the compression is so high, and the spark plug, or the whole cylinder is so hot, that its kind of running like a glo plug in a diesel. Or like in 2 stroke airplane engines- rc engines.
if its running really hot, and it gets the spark plug tang red or white hot, i'd think that with enough compression it would fire, making an endless cycle like a deisel.
just a thought - you should pull the plug and see if its messed up -
MySpree
Post by MySpree »
plugs good. iv changed the plug. but when my spree runs wot thats when it does that. and then when i turn the swich of and take the key out the scooter goes even faster!!! i have cooling fans all over the engine. i even added some.
Kikwear
Post by Kikwear »
If you've already made some modifications, thing into an airbox kill. My father's old boat with diesels has a push/pull that you can engage to shut off the airbox and thus kill the engine if the motor will not turn off. You could even pinch the fuel or vacuum lines too. No air or no fuel = no run.
vette76
Post by vette76 »
next time it does it, pull the spark plug boot off. i still think its an ignition problem.
87' spree (SOLD
12' wrx
MySpree
Post by MySpree »
ok i just got back from a ride al lil ago. i took of the boot. and it kept going for like 1 min before shutting off!!!
darat
Post by darat »
it is a POS thats all at least all of my sprees run
If it's staying running then it's dieselling, which means the jug/head are running way too hot. Try running a colder plug to see if that helps (look for the "extended operation" plug in the service manual.) If that doesn't fix it you need to play with your jetting to get the temps down b/f you have a meltdown.
Your fan shroud is in place, right?
Admin, Hondaspree.net
sp00key
Post by sp00key »
i think its geting too much air thats what my goped did just a thought
MySpree
Post by MySpree »
ok put a cfolder plug in today. and it shuts off now!!!!! yey!!!!! and it still keeps its top speed!!!
darat
Post by darat »
well thats good...
