NGK Spark Plug Info
- Gingerbread Man
NGK Spark Plug Info
Here is some good information.
- NGK Spark Plug Info - Copy.jpg (127.44 KiB) Viewed 4646 times
2007 CH80
Re: NGK Spark Plug Info
All that stuff is in Wikispreedia under spark plugs in the Tech Section.
- KeithMcFly
- BMX
Thanks guys i added this to my info book.
- Gingerbread Man
No the Spree/Elite info is there. This however is for all NGK plugs. I found it helpful to know what my VFR and CBR plugs mean as well.Bear45-70 wrote:All that stuff is in Wikispreedia under spark plugs in the Tech Section.
2007 CH80
You are wrong. Under "External Links" there is all the plug info you will ever need including what you posted.Gingerbread Man wrote:No the Spree/Elite info is there. This however is for all NGK plugs. I found it helpful to know what my VFR and CBR plugs mean as well.Bear45-70 wrote:All that stuff is in Wikispreedia under spark plugs in the Tech Section.
- Gingerbread Man
Oh snap, I apologize Bear you are correct. I wish I had explored the site more.
2007 CH80
This site has some real sharp people and several of them control what goes into Wikispreedia. They do good research and post good info found by themselves and others. You and I just have to do a bunch of reading.Gingerbread Man wrote:Oh snap, I apologize Bear you are correct. I wish I had explored the site more.
- Gingerbread Man
