Dimensions of piston?
- Gingerbread Man
I am looking for the dimensions of the piston for the NQ50 and SA50. I order a new piston kit for my Zuma and received the wrong piston and rings. Pictures are a plus, please include weight in grams if possible. Somehow I ended with a 40.50 piston and rings stamped 1.50 over. If the dimensions match I'll bore your cylinder to match the piston for a reasonable price. To clarify the piston I have is 40.50. Trafficjamz can you hook me up?
2007 CH80
Re: Dimensions of piston?
'94 up Elite SA50 is 39.0mm piston, 12mm pin. Spree, SB50, variated AF05 engines - Aero50 (85-87), Elite SS and SA50 to '93 are 41.0 mm stock pistons, 10mm pin.
- Gingerbread Man
Great info mousewheels. Mine is a 10mm piston boss. What I'm looking for is the height of the piston. And the Spree is 41.00mm also. Dose this look like a Honda piston? The one on the right.
- GEDC0086.JPG (59.03 KiB) Viewed 7802 times
2007 CH80
Hmm...Pin looks low for a Honda Spree or early SA50 with a 10mm pin. Top of pin to top edge of piston is about 0.575"
- Piston.JPG (14.71 KiB) Viewed 7795 times
- Trafficjamz
39mm af16e stock piston 58.2g on my scale
41mm nq50 stock piston 50.8g on my scale
- Trafficjamz
the one on the right looks like a elite S piston
Where did you order from? Yami dealer, Honda dealer, after market?
- Gingerbread Man
Do you have a picture of the Elite s piston?
I ordered from Autotech355 on ebay. Carlos sent me a new kit and I get to keep the wrong kit.
2007 CH80
- Gingerbread Man
Thanks, mine is 24.50mm.mousewheels wrote:Hmm...Pin looks low for a Honda Spree or early SA50 with a 10mm pin. Top of pin to top edge of piston is about 0.575"
2007 CH80
- Trafficjamz
.86 inches = 21.84400 millimeters
- Gingerbread Man
I was measuring from the top of the crown when I had 24.50mm. I believe we have now measured in the same location and came up with equal numbers. If our numbers are correct I'll say these are the same piston.
- GEDC0082.JPG (62.19 KiB) Viewed 7747 times
- GEDC0006.JPG (132.14 KiB) Viewed 7747 times
- GEDC0005.JPG (103.87 KiB) Viewed 7747 times
2007 CH80
You guys took nearidentical photos. Wee bit of scaling and we have this
- PIston_Compare.JPG (14.93 KiB) Viewed 7737 times
- Trafficjamz
Wow that is weirdmousewheels wrote:You guys took nearidentical photos. Wee bit of scaling and we have this
My piston only weighs 58.2 grams. Yours is 64.5 grams. I wonder why that is?
I hope you use that scale to weigh other peoples bags
- Gingerbread Man
Awesome!mousewheels wrote:You guys took nearidentical photos. Wee bit of scaling and we have this
I think it weighs more because it's bigger?
I weigh lots of things on that scale. Like pistons, my pre-mix oil and rollers to name a few.
2007 CH80
- Trafficjamz
Yours is not a 39mm stock piston?
