this is what happened
nitroelite419
- Goped
OK so i got my 95 elite 50 all back together. 50mm bbk, 28mm pwk, ct intake, V8 pipe, HP coil. i also eliminated the oil pump runnin 32:1 mix. So put a little gas down the spark plug and kicked. It started, blew alot of smoke. but every time i give it throttle it bogs way down and starts poppin. I have a clear vacume line on the intake and theres gas going up it a little. please help
1995 honda elite
50mm big bore
v8 pipe
high performance cdi and coil
50mm big bore
v8 pipe
- Trafficjamz
Re: this is what happened
did you change the jets in the 28mm carb?
Sounds like you are running waaaay lean.
What jets are in the carb?
nitroelite419
- Goped
no i didnt, i have no idea what jet it is, i bought it from scrappy dog
1995 honda elite
50mm big bore
v8 pipe
50mm big bore
v8 pipe
- Trafficjamz
Call scappydog and get a main and a slow jet tuning pack.
Around 130 for the main and around 45-50 for the pilot(slow) jet.
Maybe bakaracer or wheelman can give you more exact #'s
BTW have you changed the gears in that scooter of yours?
If you have not, get some !! An 82cc elite with stock gears will be DANGEROUS !!
Get at least 8.4:1 gears.
nitroelite419
- Goped
thanks for the info, and no i havent changed the gears yet, thats next on the list. im not riding it yet till its all comple. with those gears around how fast do you thank those gears will get me. i weigh 150
1995 honda elite
50mm big bore
v8 pipe
50mm big bore
v8 pipe
- Trafficjamz
Your weight has little to do with top speed, just how fast you reach it.
With 8.4:1 gears you should have a top speed around 60mph
nitroelite419
- Goped
where would be the best place to buy those gears
1995 honda elite
50mm big bore
v8 pipe
50mm big bore
v8 pipe
- Trafficjamz
nitroelite419
- Goped
what about the 7.0 gear how quick is that one
1995 honda elite
50mm big bore
v8 pipe
50mm big bore
v8 pipe
- Trafficjamz
about 65-70mphnitroelite419 wrote:what about the 7.0 gear how quick is that one
get yourself a roller tuning pack too.
http://cgi.ebay.com/ebaymotors/Variator ... 2319wt_939
nitroelite419
- Goped
if i go with the 7.0 gear what roller weight do you suggest
1995 honda elite
50mm big bore
v8 pipe
50mm big bore
v8 pipe
- Trafficjamz
I suggest you get the whole pack and mix and match to find the perfect combo for you.nitroelite419 wrote:if i go with the 7.0 gear what roller weight do you suggest
Different roller weights are needed for different trans setups.
If you change the center spring you will need to change the roller weights.
nitroelite419
- Goped
man i still have a lot to learn lol.
1995 honda elite
50mm big bore
v8 pipe
50mm big bore
v8 pipe
- Trafficjamz
nitroelite419 wrote:man i still have a lot to learn lol.
You have come to the right place for info.
We all do.nitroelite419 wrote:man i still have a lot to learn lol.
