fuel ratio
Posted: Sat Oct 30, 2010 2:57 pm
was wondering what fuel ratio everyone was running????
Keeping Spree Elite Aero 50cc and Gyro Alive!
http://hondaspree.net/hondaspree.net/phpBB3/
http://hondaspree.net/hondaspree.net/phpBB3/viewtopic.php?t=16968
Bear45-70 wrote:There is no way to know easily. Optimum air to fuel ratio for performance is 14 to 1 but economy is about 18 to 1. But without expensive equipment there is no way to tell what an individual engines fuel to air ratio is.
axo wrote:I'm doing 50:1 now with Castor oil.
Are you still running the oil pump?axo wrote:24oko 48-122 now. Did not have the time to check for the jetting yet.
I think 32:1 is too much. Way too much smoke . Should be good for a racing setup but i am using the scooter for street riding.
Plus 50:1 is what the guys at VT recommended... Remember that Castor oil is very high performance. I would go 32:1 only if i am using some cheap stuff..
I don't get it. Why are you using premix if your Elite has an oil pump? It's not a chainsaw.veedubh20 wrote:castor 927, recommed 25:1 to 32:1
all my bikes have oil pumps removed and i run premix, bear disagrees with this but o well lol... and some ppl add extra oil to tank and run oil pump for big bores......JJ Joseph wrote:I don't get it. Why are you using premix if your Elite has an oil pump? It's not a chainsaw.veedubh20 wrote:castor 927, recommed 25:1 to 32:1
I disagree with removing the perfectly good and functioning oil pump just because you want to run extra oil. Just add a smidgen of oil to the gas to bolster the oil/fuel ratio rather than have to carry a lot of extra oil to run without a pump. I do agree with "add extra oil to tank and run oil pump for big bores......".fastplastic wrote:all my bikes have oil pumps removed and i run premix, bear disagrees with this but o well lol... and some ppl add extra oil to tank and run oil pump for big bores......JJ Joseph wrote:I don't get it. Why are you using premix if your Elite has an oil pump? It's not a chainsaw.veedubh20 wrote:castor 927, recommed 25:1 to 32:1
