Spree takes a while to start
Todler
Post by Todler »
Hello,
I have a 1985 Honda Spree that is in pretty good shape, and runs well. The only problem that I have is that it starts hard. If I have not used it in a while, it takes several minutes of cranking to start. After it is started, or I have been riding it, it starts fast. I have replaced the spark plug, and checked to make sure the muffler is not plugged. Any thoughts on what the issue could be?
Thanks a bunch.
bitteraspects
Post by bitteraspects »
it could be anything from battery to choke. best bet is to troubleshoot
sp00key
Post by sp00key »
well they need some time to if u have rideing it in a wile
Todler
Post by Todler »
I have already replaced the battery, but I didn't think about the choke. Forgive me for asking as I am not familiar with how the choke works on the spree. Is it an automatic choke or where would I find information on how to troubleshoot/fix the choke?
It's called the bystarter on Spree. Read up on it in tech docs. I'm betting yours has issues.
Admin, Hondaspree.net
Mike
Post by Mike »
if its been in storage for a while you should definately clean the carb and check tank for rust.
'86 Black/red two-tone Honda Spree, pretty much stock.
MySpree
Post by MySpree »
yea u should.
