i need a list of part where i can get them and everything i need to get more speed and hp
all i did was pulley mod and gutted my muffler
need help
Honda spree 86 faster than 35 possible
honda spree 86
- spree-rider
Re: Honda spree 86 faster than 35 possible
48 mm bbk ebay seller chopchop123
gears ebay chopchop123
uni pod filter
sb50 intake and reeds
porting
3.0x10 rear tire
DUDE, SWAP IN A DIO!
uni pod filter
porting
3.0x10 rear tire
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
mountain bar
Xtra-10
- Petrock's 1984 Spree
What he said. Im doing it the hard way on my '84 by upgrading the stock engine and tranny. But everyone is telling me swap in a different motor ie a dio. If you want to go faster than 40+ then dont try to do it on the stock engine, im hearing its not realistic. But after im done with upgrading mine in a few months i hope to prove em wrong
The easy route is to swap in and bolt up a different motor, something that is variated.
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
I've got an entire SE50 engine swap for Spree for sale. See For Sale section of board.
Admin, Hondaspree.net
Chopchop*123 is actually forum member Tazland001. PM him from the forum here and he will fix you up at a discount from the flea-bay price.spree-rider wrote:48 mm bbk ebay seller chopchop123
uni pod filter
porting
3.0x10 rear tire
It is posible some people here are 2 quick 2 give up and take the easy way out 40mph aint that hard 2 get 2 with the spree motor use the parts above some porting 2 the jug and a good exhaust and your away laughing watch the tuning people think im lieing but my spree does 52mph but i hav a custom vari fitted 2 it exstensive work 2 motor was needed like boring crank case 2 suit a larges crank a custom spacer 4 the jug getting the rear gear shaft that the clutch bolts 2 extended 2 line up with new position of the variater and a custom cover 4 it all which has been the hardest part of all and are still working so dont give up like others here do
