Honda spree 86 faster than 35 possible
Posted: Mon Nov 15, 2010 8:03 pm
by honda spree 86
i need a list of part where i can get them and everything i need to get more speed and hp
all i did was pulley mod and gutted my muffler
need help
Re: Honda spree 86 faster than 35 possible
Posted: Mon Nov 15, 2010 9:26 pm
by spree-rider
48 mm bbk ebay seller chopchop123
gears ebay chopchop123
uni pod filter
sb50 intake and reeds
porting
3.0x10 rear tire
DUDE, SWAP IN A DIO!
Posted: Tue Dec 14, 2010 9:55 pm
by Petrock's 1984 Spree
What he said. Im doing it the hard way on my '84 by upgrading the stock engine and tranny. But everyone is telling me swap in a different motor ie a dio. If you want to go faster than 40+ then dont try to do it on the stock engine, im hearing its not realistic. But after im done with upgrading mine in a few months i hope to prove em wrong
The easy route is to swap in and bolt up a different motor, something that is variated.
Posted: Tue Dec 14, 2010 10:01 pm
by noiseguy
I've got an entire SE50 engine swap for Spree for sale. See For Sale section of board.
Posted: Tue Dec 14, 2010 10:23 pm
spree-rider wrote:48 mm bbk ebay seller chopchop123
uni pod filter
porting
3.0x10 rear tire
Chopchop*123 is actually forum member Tazland001. PM him from the forum here and he will fix you up at a discount from the flea-bay price.
Posted: Sat Dec 18, 2010 3:53 am
by ae86guy
It is posible some people here are 2 quick 2 give up and take the easy way out 40mph aint that hard 2 get 2 with the spree motor use the parts above some porting 2 the jug and a good exhaust and your away laughing watch the tuning people think im lieing but my spree does 52mph but i hav a custom vari fitted 2 it exstensive work 2 motor was needed like boring crank case 2 suit a larges crank a custom spacer 4 the jug getting the rear gear shaft that the clutch bolts 2 extended 2 line up with new position of the variater and a custom cover 4 it all which has been the hardest part of all and are still working so dont give up like others here do
