Helmet storage
Helmet storage
How do you store your helmet?
In a bag? A box? On a shelf? Under a seat? .....
Re: Helmet storage
I have a nice helmet bag that I put the helmet in and then store the bag in the scooter gear box.
NiQue
Re: Helmet storage
always place it in a cloth like bag then place it in a box..
there are little kids in our place so i have to keep it in a place the kids will not reach..
Re: Helmet storage
You hit the nail on the head. I use to keep my main helmet under a bench by the door. My nephew decided that there was too much stuff in my helmet and stripped it down to the styrofoam shell. I used to use bags but they were stolen out of the back of my pickup years ago. Now I am trying to figure out what I should get to finally replace them.NiQue wrote:always place it in a cloth like bag then place it in a box..
Re: Helmet storage
An extended cab truck gives you tons of space for your helmet and a wide array of other items.eliteguy50 wrote:You hit the nail on the head. I use to keep my main helmet under a bench by the door. My nephew decided that there was too much stuff in my helmet and stripped it down to the styrofoam shell. I used to use bags but they were stolen out of the back of my pickup years ago. Now I am trying to figure out what I should get to finally replace them.NiQue wrote:always place it in a cloth like bag then place it in a box..
Re: Helmet storage
I ended up selling the truck and getting an SUV.Bear45-70 wrote:An extended cab truck gives you tons of space for your helmet and a wide array of other items.
Re: Helmet storage
So you bought a station wagon.eliteguy50 wrote:I ended up selling the truck and getting an SUV.Bear45-70 wrote:An extended cab truck gives you tons of space for your helmet and a wide array of other items.
Re: Helmet storage
They live up on a high shelf. The ones I use often don't get bagged anymore, but the backups (both mx helmets) stay in the bag for now.
My "station wagon" can go anywhere on this island that doesn't require a boat, has towed out many 4wd "trucks", the backseat can fit large adults, and it's 100% lockable. Not to mention subzero AC, and room to spare even after the stereo system.Bear45-70 wrote: So you bought a station wagon.
Sure there are alot of unibody poser SUV's out there, but there are still a few that have a full frame design, dedicated low range gears, and stock skidplates that aren't made of plastic.
4r ftw!In 2040 they say we're going away
Re: Helmet storage
It is still a station wagon, regardless of the drive system under it or whatever cute name the manufactures stick on it to make your ego not shrivel when owning one.808BMW wrote:
4r ftw!
Re: Helmet storage
Hah, typical Bear. So what awe inspiring manly man's truck do you drive? I'm guessing big, old, and american. Pieces of crap in my opinion, I'll take a "station wagon" any day
Re: Helmet storage
I have 2 trucks, a 1999 Ranger XLT with 4.0 for the light stuff like towing the ski boat or taking the quads to the trail head. Then for the real work I have a 1986 F250 heavy duty (a light duty 1 ton) with a warmed over 460 and a 4.10 rear end for the camper or any one of my two dual axle trailers. Both trucks are extended cabs.808BMW wrote:Hah, typical Bear. So what awe inspiring manly man's truck do you drive? I'm guessing big, old, and american. Pieces of crap in my opinion, I'll take a "station wagon" any day
Re: Helmet storage
A Bronco XLT would be better compared to a convertible than any wagon. Next will be an Excursion though. I had a '79 F-250 with a 460 and dual lockers, from back when they made real trucks using fully boxed frame rails. The best mud truck I ever owned.
Re: Helmet storage
Yeah, they had carbs so you could hot rod them easily.eliteguy50 wrote:A Bronco XLT would be better compared to a convertible than any wagon. Next will be an Excursion though. I had a '79 F-250 with a 460 and dual lockers, from back when they made real trucks using fully boxed frame rails. The best mud truck I ever owned.
Re: Helmet storage
Carbs? With the smog crap from back then, it took a lot more than just a carb to bring it to where a 460 should be.
But the EPA would not like if I typed any details.
Re: Helmet storage
They suck * and don't scare me. A straight up timing set instead of the post 1972 emissions 4┬░ retarded set and a high lift RV cam. A good set of 9.5 to 1 pistons, some exhaust port work, recurved dist. and a small tube set of headers plus a non-emissions Holley carb reworked by me. Picked up 2.5 mpg and the low end throttle response is amazing.eliteguy50 wrote:Carbs? With the smog crap from back then, it took a lot more than just a carb to bring it to where a 460 should be.But the EPA would not like if I typed any details.
