86 fuel tank on 85 spree?
Posted: Wed Nov 24, 2010 4:20 pm
by mattman
Is the 86 fuel tank different from the 85 or can I swap one for another?
Re: 86 fuel tank on 85 spree?
Posted: Wed Nov 24, 2010 5:20 pm
by bradthreee
The petcock connections are different. Also the fuel sender on an 86 is a 3 wire and the 85 is a 2 wire.
The 85 tank itself will bolt up no problem between all year Sprees.
Posted: Wed Nov 24, 2010 5:42 pm
by mattman
Thanks, So If I were to swap over the whole system... tank and petcock assy. from an 86 to my 85 everything should work out other than the fuel gauge?
Posted: Wed Nov 24, 2010 6:08 pm
by martynkim
mattman wrote:Thanks, So If I were to swap over the whole system... tank and petcock assy. from an 86 to my 85 everything should work out other than the fuel gauge?
Yes, you are right.
Posted: Wed Nov 24, 2010 6:26 pm
by mattman
Either of you guys have a good tank and/or petcock you want to sell? The interior of mine is so rusted that I think I may be better off finding a replacement. So far I have run across a few 86's so that's why I was asking.
Posted: Wed Dec 01, 2010 1:04 pm
by Trafficjamz
bradthreee wrote: Also the fuel sender on an 86 is a 3 wire and the 85 is a 2 wire.
I thought the 3 wire sender was an '87 thing (not 1986)
..... I could be wrong.
Posted: Thu Dec 02, 2010 1:27 am
by WestcoastSPREE
My 86 has a 3 wire so I don't know if there was an early 86 model that was different from a late 86.
Posted: Thu Dec 02, 2010 10:01 am
by Trafficjamz
Trafficjamz wrote:bradthreee wrote: Also the fuel sender on an 86 is a 3 wire and the 85 is a 2 wire.
My scooters are all made from mix and match parts.
like I said....I could be wrong.
Posted: Thu Dec 02, 2010 7:31 pm
by martynkim
mattman wrote:Either of you guys have a good tank and/or petcock you want to sell? The interior of mine is so rusted that I think I may be better off finding a replacement. So far I have run across a few 86's so that's why I was asking.
I have an 87 tank and an 85 but need to verify. Both nice and clean.
