Running without a bystarter
gman75
Post by gman75 »
After limited sucess with a spree carb, I am going to try to use an elite carb on my elite engine.
Problem is my elite carb is cracked and deformed in the area where the bystarter fits to it, so a bystarter won't fit. How can I run the spree without a bystarter. Do I need to stick something in the hole before/after starting, etc?
Scooter-less
JF
Post by JF »
It's probably not the best idea to run a carb that cannot utilize the bystarter correctly, but if you must, you might try finding an old bystarter needle valve assembly first. Then, push it into the hole in the middle where it normally goes, and tape it off good. Of course, then you won't have a working choke, so that defiantly shouldn't be your first option. I would highly suggest either getting another carb that isn't deformed, or try and repair the one you have. If you can, post a picture of the deformed area; that way either I or someone else can take a look at the pic, and let you know whether it is repairable(or worth repairing) or not.
JF
1978 Puch Free Spirit, a 1980 Honda NC50, a 1985 Honda Spree, and a 2005 Yamaha Zuma. Gotta love two-stroke power...:)
...or get an aftermarket carb with a manual choke. Though I'm sure you're tired of spending on that beast.
maddog
Post by maddog »
Yes, www.mopedwarehouse.com sells 14mm manual carbs in either lever or cable operated.
85spreeelite
Post by 85spreeelite »
MadDog? 14mm is the stock size of elite carbs?
gman75
Post by gman75 »
JF,
If I tape off the bystarter hole like you said, it would be hard to start but fine once its warm and running, right?
Greg
Scooter-less
sp00key
Post by sp00key »
i ran mine whit out a bistarter and it was fine for like 4 mouth then i got a bistater and its ran like new but now i dont have a air box lol
darat
Post by darat »
HAHAH b/c u are to cheap to buy mine
MySpree
Post by MySpree »
yea MY BYSTARTER!!!
darat
Post by darat »
oh no he got a new one urs fryed...
JF
Post by JF »
Greg,
Yes, it'll be a little hard to start on cool mornings, but it should run fine once it's warmed up. Make sure that you have a needle valve assembly off of a by-starter pushed in there all the way until it seats, and then tape it off good, otherwise the bike might run too rich.
Good luck,
JF
