Good tip here - your clutches from the AF16/18 and so on as well as SE50 clutches AND bells fit the GY6 engine. I put on an SE50 clutch some time ago just for experimentation and was very surprised the four stroke could make that much power!
The factory two stroke clutch is basically a performance built clutch to the 4 strokes because of the two strokes more rapid rotation. Try it once, you will be amazed.
Another good tip is to run your clutch shoes a few passes over a wire wheel on a bench grinder if they've gone smooth as glass. It makes them bite hellishly hard
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned
