just got a honda elite 50 1989 off craigslist...
azndude3141
Post by azndude3141 »
everything works extrmeley well. it idles insanely quiet and starts extremely easy with electric and kick start. however, everytime i turn, it makes a click everytime you turn past the halfway mark. it kinda get anoyying so i tryed removeing the 3 nuts on the front cover but the cover wont come off. is it suposed to make that clicking noise? also, how much oil should i put in it? to the brim or just wait until i see the oil senser light up? he didnt give me an owner's manual :(. thanks for your help.
evilone
Re: just got a honda elite 50 1989 off craigslist...
Post by evilone »
Fill the oil container, the oil level sensor lights up when it senses no or low oil not when level is where it should be. Not sure about the clicking, sounds like something catching.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone
Post by evilone »
The throttle cable, speedo cable, and both brake cables run behind the front cover and move when handlbars are turned. That's what might be catching?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
azndude3141
evilone wrote:Fill the oil container, the oil level sensor lights up when it senses no or low oil not when level is where it should be. Not sure about the clicking, sounds like something catching.
so i just fill oil to the top?
evilone
Post by evilone »
Yes. Use a good oil like Honda GN2 "injector" oil.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Post by eliteguy50 »
You need to remove more than the three nuts on the front of the cover. There are also screws that screw from that glovebox panel into the front plastic, look around the edges.
djm209
Post by djm209 »
just put oil in my first scooter and you asked a question i was thinking about....i filled my oil up pretty much to the top and was wondering just now if thats a good idea...
im assuming you said it was ok. i used great oil.
thanks!!
everyday i am closer to fine
86 Honda Aero 50
87 Honda Elite 150
Fill to the little indicator below the cap. If you overfill it isn't a big deal, but spilled oil is a pain for a long time.
djm209
Post by djm209 »
thanks!! i think im just gonna leave the oil in there and next time wont fill it up so far....
lesson learned!!!
86 Honda Aero 50
87 Honda Elite 150
