Contemplating some upgrades...
gulfstorm
Post by gulfstorm »
Hello All,
I have been on this forum for about a year now. Got two sprees, 85 and 86. Looking to do some upgrades on one of them. My 86 runs quite well but there is an air leak somewhere in my intake or carb system. My screw on the carb has to be in all the way for the thing to run without stalling. That aside I am looking at the BBK purchase but I havent been able to find a step by step guide for doing it anywhere. I understand that it is quite easy to do and I have some experience with working on engines. That is the only upgrade I am looking it but I understand that a lot of people also do gears! I ll keep on looking at these forums for answers.
Cheers,
gulfstorm
'12 Audi A3 s-line
'00 Porsche Boxster S
86 & 85 Honda Sprees
odinxxix
Re: Contemplating some upgrades...
Post by odinxxix »
it really isnt that hard and the kit from tazland001 will have the instructions with it. and i would go woth the 48 mm bbk and his gears. while you are at it get his exhaust pipe if they are for sale now, i know you just said the bbk but all will make for a better scoot :imo: :thumbwink: good luck with the build and we will be here to help. :thumbsup:
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
gulfstorm
Post by gulfstorm »
Thanks a lot. Great to hear that they come with instructions. I ll look into gears as well. Does the stock carb work okay with the bigger bore?
'12 Audi A3 s-line
StrokedSr
Post by StrokedSr »
yo,,if you can jet your stock carb then it will work,with the bbk ,its going to crave more fuel,up your main jet and put an exhaust and punch your airbox., oh and gears like you were sayin so your not sitting at a high rpm :wink:
1988 yamaha zuma
polini evolution kit
polini evolution 2 exhaust
polini big reed manifold
dellorto 21mm
keli clutch
keli variator
Actually the stock carb, with a rejet, will work with the 44mm, but it just ain't big enough for the 48mm. To get the most out of the 48 mm you need more carb.
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
You could always mate a CT intake from a dio to it :geekdance:
Its not hard to do at all, just takes a lot of time
With that intake you could then attach a bigger carb, whatever size you want
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
fastplastic
Post by fastplastic »
just go with the 44, if you go with the 48 and ct manifold go luck finding a carb that isnt to big and it tuning it is impossible.... well next too..... the 48 came out way to fast before there where upgrades to keep up with it..... my ported 44 is asking for more air as it is.....
Well yeah I dunno if mine will work yet or not. I managed to snag a deal on eBay where the ct came with a 21mm oko and high flow k&n. If it doesn't work then there are always alternatives
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
76duece
Post by 76duece »
I actually started with the 48 kit and gears, but went to the 44 and it seems much more tunable. Runs great, good power. All else is stock. I'm running an 85 main jet, punched 4 7/8 inch holes in the top of the stock air box, cleaned and oiled the filter, all is well. I'm still in the break-in stage, but it seems to be running great so far. It's set at about two turns on the mixture screw. I'm running a little oil in the gas plus the oil injection. Hope this helps.
Larry
Did you go down to the 44 because it was more tunable?
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
fastplastic
more then likely i have been referring ppl to the 44mm out of experience with both kits
Ah gotcha, sooo maybe bigger isnt always better
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Petrock's 1984 Spree wrote:Ah gotcha, sooo maybe bigger isnt always better
If you want to stay with the stock intake and exhaust systems, then yes, to big is bad.
spree-rider
Post by spree-rider »
i dont think exaust would be a problem with taz's pipe coming sone :wink:
86 spree
sb 50 intake and reeds
3.00x10 rear tire
waxed
99Polaris indy 700
harliquim paint
2" bar riser
lefty throttle
ice scratchers
SLP tri keel skis
ported
high compression head
chrome low windshield
mountain bar
Xtra-10
I ALWAYS KEEP ONE ROLLED
Thats exactly what im hoping for :smile:
48bbk, 21 mm oko CT, taz exhaust, taz gears....im hoping for the best :geekdance:
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
