Aero 50 motor in a spree?
Posted: Tue Jan 04, 2011 7:52 pm
Will a aero 50 motor fit in a spree? if so what mods need to be done?
Andrew
Andrew
Keeping Spree Elite Aero 50cc and Gyro Alive!
http://hondaspree.net/hondaspree.net/phpBB3/
http://hondaspree.net/hondaspree.net/phpBB3/viewtopic.php?t=17513
ok Thanks bear, is the mount like the one you have to make for the dio motor swap?Bear45-70 wrote:Yes, it is only slightly wider than the Spree engine. However you have to fabricate an engine mount.
Yes.ANDREW wrote:ok Thanks bear, is the mount like the one you have to make for the dio motor swap?Bear45-70 wrote:Yes, it is only slightly wider than the Spree engine. However you have to fabricate an engine mount.
The Leo Vince SP3 is available for the af05 Aero 50 engines. I do not know of any pipe available for the '83-84 engines.ANDREW wrote:Ok cool also do you know if there is a tuned pipe available for the aero 50?
There are more than two bores. I can pull three off the top of my head: Polini 47mm/65cc, CMR 46mm/63cc, Taz 44mm kit. I don't know if malossi still makes a kit but there are some sitting on a shelf that you see for sale every now and then.fastplastic wrote:theres not as many parts for the afo5 as the dio the afo5 has one maybe two bbks and a couple pipes the dio is way more upgradeable and can reach a lot higher speeds then the afo5 if thats what your looking for.....
theres five of them there all not so easy to get though..... follow link to see them....eliteguy50 wrote:There are more than two bores. I can pull three off the top of my head: Polini 47mm/65cc, CMR 46mm/63cc, Taz 44mm kit. I don't know if malossi still makes a kit but there are some sitting on a shelf that you see for sale every now and then.fastplastic wrote:theres not as many parts for the afo5 as the dio the afo5 has one maybe two bbks and a couple pipes the dio is way more upgradeable and can reach a lot higher speeds then the afo5 if thats what your looking for.....
