i know that this isnt a yamaha fourm but please help
spewya
Post by spewya »
i have a yamaha razz that i bought non running and ive been trieng to get it running but it just aint geting spark what are all the posibalities that could be rong with it.. thanks
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
martynkim
Re: i know that this isnt a yamaha fourm but please help
Post by martynkim »
spewya wrote:i have a yamaha razz that i bought non running and ive been trieng to get it running but it just aint geting spark what are all the posibalities that could be rong with it.. thanks
No spark plug?
Sorry I'm in a mood today. :ndance:
spewya
Post by spewya »
ive tried multupule plugs
killerpancake
Post by killerpancake »
bad wire, bad coil, start at the plug and back track.
(Previous)
87 honda spree
85 honda spree
(Current)
88 yammy razz
(parts bike)
another 88 yammy razz
These CDI ignitions are super easy to troubleshoot. First off get a spark test from Harbor Freight or place of your choice.
http://www.harborfreight.com/inline-ign ... -4424.html
Now disconnect the run/stop switch and the ignition switch. Do you have spark now. If you do, one of the switches is bad or you have the run/stop switch in the stop position (that should be a standard check whenever you engine will not start).
Next you need a service manual and a volt/ohm meter to check the ignition coil, CDI, the stator and the pulse generator (trigger for us old timers). If they all check good then you get to check the wiring harness for shorts and opens. But you can't troubleshoot this stuff without a service manual.
spewya
Post by spewya »
thanks ill try it an let you guys know
