Page 1 of 2
good score
Posted: Sat Jan 08, 2011 7:30 pm
by that guy
I bought a af18e complete got it cheap the guy said it was seized got it hme took of the belt cover and found the kick start was jammed locking on to the end of the crank.I turned the crank and it turned over as it should. So i fixed the kick starter put the cove on kicked it over a few times and it felt real good then i wired it up 2 the nq following threads from here thanks for that made it alot easyer.I added some premix gas 32:1 hit the starter after a few cranks it fired up and ran like a champ WOW im so stoked justt got 2 mount it up get it moving then i can get some mods under way ill post some pics when i get some parts
Re: good score
Posted: Sat Jan 08, 2011 8:24 pm
Congratulations on turning "junk" into treasure!
What scooter was the engine's original home?
Re: good score
Posted: Sat Jan 08, 2011 9:40 pm
by veedubh20
:D :D
the stator for japan af18e only. you can use 87SE50 ,88-93 sa50 will bolt on the japan af18e..
Re: good score
Posted: Sat Jan 08, 2011 9:58 pm
by that guy
Unsure wat it was out of wat bikes hav this engine
Re: good score
Posted: Mon Jan 10, 2011 12:05 am
by that guy
Can no body tell me wat bikes hav this motor
Re: good score
Posted: Mon Jan 10, 2011 12:13 am
Honda-san gave up on certifying 2-strokes in the EPA-Infested USA with the 2001 Elite, which featured the AF16 block.
Dio midels overseas, and possibly Canada (?) Followed with the next-generation 18 engines. Some Gray Market US importers brought in Dios, but not sure what years used the 18, it varies by country anyway.
Re: good score
Posted: Mon Jan 10, 2011 12:58 am
by that guy
Ok then thanks
Re: good score
Posted: Mon Jan 10, 2011 1:16 am
According to my engine cheat sheet, the AF18E engine was used in The SK50MJ and SK50MK also known as the DIO, which we made in 1988. It was also used in the SE50MSJ AKA DJ-1RR also in 1988.
Re: good score
Posted: Mon Jan 10, 2011 11:35 am
by eliteguy50
I think the af18 was used into the mid 90's.
Re: good score
Posted: Thu Jan 13, 2011 7:30 pm
by maddog
build something fast bear so i can pink slip your sorry old * :smile:
Re: good score
Posted: Thu Jan 13, 2011 7:36 pm
maddog wrote:build something fast bear so i can pink slip your sorry old * :smile:
I keep hearing your bragging about racing, but the sad part is no one else on the planet has ever seen, heard or even heard second hand about you winning anything. So until you actually have proof of your race winnings . I will laugh at you because at this point I will claim my stock Spree as faster than anything you have and it GPS' out at 28.4 mph.
Re: good score
Posted: Thu Jan 20, 2011 7:58 am
by fastplastic
well bear then my spree is faster then your spree......
Re: good score
Posted: Thu Jan 20, 2011 11:05 am
by spree-rider
fastplastic wrote:well bear then my spree is faster then your spree......
plastics spree has a dio :wink:
Re: good score
Posted: Thu Jan 20, 2011 11:13 am
by fastplastic
my nq spree did 43 just time to do it right and have two dio sprees
Re: good score
Posted: Thu Jan 20, 2011 11:24 am
by spree-rider
how much ofr your 44mmbbk and the motor that its one. no exaust and no rear wheel or shock. :wink:
