base gasket on 94 elite s
bmccaffry
Post by bmccaffry »
What do you guys recommend for base gasket removal? Any tricks?
94 Elite S
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
stopsign31
Re: base gasket on 94 elite s
Post by stopsign31 »
B. Mc.,
Do a search. Wheelman has several posts on best way to accomplish this. Whatever you do, DO NOT scratch or gouge the case :sad: , this will result in a poor seal condition. Take your time, young man.
1994 Elite SR (Black & Purple)
Tazland 51mm BBK (2nd kit -- fried the 1rst)
YMS- V8 pipe
9 : 1 gears Pirelli SL26 3.0 Tires
OKO 28mm carb // chrome CT manifold // Koso filter
Ruckus variator
Blue tension spring // 2K clutch springs
Get the sharpest putty knife you can find. Then throw it away! :)
Sinceriously, this is the ugliest, most PITA task any assembler ever performs, but worth the time it takes.
I use a stainless-steel razor in a plastic holder for a buck at Harbor Freight. Make sure you hold it flat and resist the temptation to start in with the corner of the blade. A gouge will have Bad Consequences.
Shave carefully a mm at a time. Stop when you see aluminum on any portion of the mating surface and move to the next segment.
Once all recognizable paper is stripped off, move to a fine abrasive over a block of straight wood or metal and sand away all traces with the block held rigorously square to the surface.
Slather the new gasket liberally on both sides with hi-temp grease to avoid having to do this next time.
bmccaffry
Post by bmccaffry »
As always thank you very much!
94 Elite S
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
bmccaffry
Post by bmccaffry »
Also I knew of areosol gasket removers. Could i spray the gasket and simply wipe it off with a rag??
94 Elite S
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
I've never found the aerosols all that effective, and they sure can make a mess of your engine. And your fingers :shock: .
Some of the aerosol work well but you have to be patient. The stuff does not work "NOW!" The outboard manufactures have several products between them that do work (all the outboards have aluminum blocks too) and as a guy who did this professionally, gouging the aluminum is way too easy even for someone who does it all the time.
bmccaffry
Post by bmccaffry »
Thanks again guys...I am by know means a professional, I would say handy but no professional!! LOL. I think I will try some gasket remover first...let it sit over night and see how it looks or how easy itcomes off the next day. I have my old piston, head, and cylinder off now for sale on here and on ebay so I can have a couple extra bucks towards a 50 BBK kit. So Believe me I will be patient with it and get everything cleaned up in th emean time. I have rags and a towel over the whole scooter to assure that it stays clean. Lookin forward to spring should be fun!! Someone told me my stock carb with a 85 main jet and the needle set to the lowest setting on the throttle would be ok...do you guys agree with this?? I plan on premixing to 4 oz per gallon. Sound about right?? Just wanting to make sure...afterall this is my first scoot project would hate to lock it up!! Thanksguys...this project would have never happened without your advice and expertise.
94 Elite S
De-restricted
Ruckus vari 7g
9:1 secondary gears
tai big bore 50mm
maddog
Post by maddog »
on my 108cc stroker i use 2 oz per 0.9 gal on my aero so 4 oz may create fricton heat and lead to a seize....
maddog wrote:on my 108cc stroker i use 2 oz per 0.9 gal on my aero so 4 oz may create fricton heat and lead to a seize....
Image And that is relevant to removing stuck on gasket material how? Is your reading comprehension really that low or are you just too stupid to know what is going on.
evilone
Post by evilone »
maddog was replying to this
bmccaffry wrote:I plan on premixing to 4 oz per gallon. Sound about right?? Just wanting to make sure...afterall this is my first scoot project would hate to lock it up!!
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
