zuma bottom end?
zuma bottom end?
Hi all,I'm just testing the waters, I'm toying with the idea of getting rid of my zuma motor. The problem is I picked it up with no top end ,exhaust or flywheel and I cant rotate the assembly with the kickstart.. What is it worth? I'm considering making it a 3 wheeler with atv rear end or putting my aero 80 motor in it. Any ideas ? Btw its a 2000 pre-bug
Re: zuma bottom end?
If you remove the belt cover, can you spin the crank by hand?
Went out and ,yup crank turns
