big bore kit
honda spree 86
big bore kit
Will a dio big bore kit fit on a spree
Re: big bore kit
nope. the bolt patterns are different. and im thinking even if it did bolt down the boost and exhaust ports would be all wrong for the storke of the spree. but its just a guess. sorry guys for not haveing all the correct answers.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
- Trafficjamz
Re: big bore kit
honda spree 86 wrote:Will a dio big bore kit fit on a spree
Short answer = NO
The Intake transfers would not line up correctly.
The bolt spacing is actually the same.
- fastplastic
Re: big bore kit
find and buy a 44mm taz big bore kit if you want a kit for your spree.....
- Munstah666
- Goped
Re: big bore kit
Swap an Af16E in there, aftermarket choice is endless...GL!
µùѵ£¼Òü«Òé╣Òâ╝ÒâæÒâ╝Òâ×Òâ│
Re: big bore kit
After much delay I am getting ready to start on my 48mm BBK for my spree. I thought I might just join this discussion. I hope it is okay to field some questions here.
This project BBK will have a 17.5mm Arreche carburetor (flange type) sb50 reeds, expansion chamber (Daywot came up for me).
Of course the BBK came form Taz. My first question is about the piston. Would it help to open up a window in the piston like many other better performing 2-stokes have? If I understand correctly that is what you guys refer to the boost port side of the piston.
Also would it help to open up the schnuerle ports some? Well the little bit that jug and block will allow without grinding too much away from the sealing surface of the cylinder base gasket?
Re: big bore kit
i think you should show a pic of this expansion chamber for the spree. we did not know of one except the one taz is working on.
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Re: big bore kit
The pipe is not for a spree. It for a one of the lower end Yamaha scooters of about the same vintage as the spree. I am going to have to do some pretty easy minor mods to bolt it up. It is made by Proma Exhaust Systems and has TDS1121196 and PCM74420 S PI stamped on the mounting bracket. I have searched online but have not found anything else about it. Sorry.
It would not be easy for me to send a picture right now but at some point I will gladly post a picture.
Any word on the Taz pipe? It has been at least 6 months since the talk began.
Re: big bore kit
probably a razz
1988 yamaha zuma
polini evolution kit
polini evolution 2 exhaust
polini big reed manifold
dellorto 21mm
keli clutch
keli variator
dellorto 21mm
keli clutch
keli variator
