Engine starts, Throttle twists freely and nothing happens
ofarevaluti0n
Post by ofarevaluti0n »
I ride a 1984 spree, which has been running great until I started riding it in the cold. The last time I rode it, the throttle froze wide open, and I couldn't slow the moped down. Put the spree inside to thaw, now, it starts fine, and runs at an Idle. But when I try and twist the throttle, the throttle twists freely, no resistance, and the bike stays at idle. I'm guess the cable broke, but I'm not sure. Can anyone help?
fizzle
Post by fizzle »
unscrew the carb cap and twist the throttle cable.
does anything happen?
if not,
you need a new throttle cable.
the carb cap is the little thing that the throttle cable goes down into.
should be pretty to get off.
okay stay safe
Bad/sticky throttle cables = crash waiting to happen.
myhonda
Post by myhonda »
its your cable. i had that happen to me. i jus put a bolt on the end of the cable and put a brake lever form a bike to replace throtle
