1986 Honda spree nq50. Piston rings.
CamTastic
Post by CamTastic »
Whats the easiest way to put in some piston rings without breaking them?
I do not have a compressor for the rings. let me know the safest way to do so. thanks.
- 1986 Honda Spree Nq50.
evilone
Re: 1986 Honda spree nq50. Piston rings.
Post by evilone »
The mark on the rings facing up. Then "roll" the rings down one groove at a time.
And you would want a ring expander not compressor :wink:
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
CamTastic
Post by CamTastic »
I ment like whats the easiest way to put the head back on so you don't break the rings haha.
Petrock's 1984 Spree
Post by Petrock's 1984 Spree »
There is a how-to on how to install a bbk in the advanced tech section and it walks you through step by step :smile:
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
It is in the performance section of Wikispreedia.
http://hondaspree.net/wiki/index.php5?t ... it_Install
CamTastic
Post by CamTastic »
Thanks guys. For a noobie would it be easier just to remove the motor from the frame and do it that way?
evilone
Post by evilone »
CamTastic wrote:Thanks guys. For a noobie would it be easier just to remove the motor from the frame and do it that way?
I wouldn't remove motor.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
evilone
Post by evilone »
I just looked at that wiki link. I leave piston on the crank rod, compress rings by hand at the 10 and 2 locations, and slide cylinder down piston. Just hold the springs so the cutouts in the cylinder skirt are lined up with you fingers.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Post by eliteguy50 »
If you don't like the bending over, it can be. The spree frame is more intrusive than the sa50 frame that was used for those pictures. I usually just prop up the spree and drop the shock, allowing the motor to swing down more. This way you won't have to worry about oil/fuel lines or wires, but you have more room to work the cylinder on.
If this is the ring compressor you are talking about, I find doing it by hand to be easier on these engines.
http://www.amazon.com/OEM-27039-Piston- ... B0014WH9VQ
eliteguy50 wrote:If this is the ring compressor you are talking about, I find doing it by hand to be easier on these engines.
Don't bother with that, a simple hose clamp will work just fine.
