oops !!
Posted: Tue Mar 01, 2011 7:52 am
by josh999
Hello
After getting my Mini Melody ( eve smile ) home after 2 months of being at work in the garage.I was fininding it hard to start and the kickstart wouldent return the correct position, I found this
http://i1081.photobucket.com/albums/j35 ... kstart.jpg
http://i1081.photobucket.com/albums/j35 ... start1.jpg
http://i1081.photobucket.com/albums/j35 ... start2.jpg
Anybody got any ideas on what might have gone wrong to mess that up in such a bad way??
many thanks
Josh
Re: oops !!
Posted: Tue Mar 01, 2011 9:23 am
by PolarIce
Here you go... I fixed your image links....
josh999 wrote:Hello
many thanks
Josh
Re: oops !!
Posted: Tue Mar 01, 2011 10:15 am
by josh999
Cheers mate
How did you do that ??
What did I do wrong lol
Re: oops !!
Posted: Tue Mar 01, 2011 10:25 am
I would replace the gear it runs against too or chances are you will have the same issue again.
Re: oops !!
Posted: Tue Mar 01, 2011 10:28 am
by PolarIce
josh999 wrote:Cheers mate
When your posting... click the Img tab at the top and then cut/paste your link in-between those markers...
Easy Breezy...
Re: oops !!
Posted: Tue Mar 01, 2011 12:02 pm
by Trafficjamz
When you kick start the scooter, KARATE is not necessary
When you get this part replaced......
Kickstart a little softer.
Re: oops !!
Posted: Tue Mar 01, 2011 12:17 pm
Trafficjamz wrote:Anybody got any ideas on what might have gone wrong to mess that up in such a bad way??
Re: oops !!
Posted: Tue Mar 01, 2011 5:38 pm
by eliteguy50
Start by applying pressure to engage the gears rather than jaming them together suddenly.
Re: oops !!
Posted: Wed Mar 02, 2011 8:40 am
by josh999
HaHa
Loved the Karate comment
IÔÇÖm not that rough I promise, I think it might have had some abuse at work while I was on sick leave. (probably trying to hotwire it or something stupid)
Anyways. . . I went outside to look at the scooter this morning and noticed that the half circle gear thing? Was catching the side of the engine casing?????
Anybody got a kick start diagram?? I think thereÔÇÖs a few bits missing ( washers ect ) I donÔÇÖt think the last guy put it back together properly
Cheers
Re: oops !!
Posted: Wed Mar 02, 2011 9:37 am
If the half-moon is hitting the case, one of 2 things may be wrong.
1. If you're lucky, it's just an assembly issue. A snap-ring (circlip) holds the kickstart shaft in the correct position to keep it away from the case. If it's missing, the spindle slides outward and the half-moon hangs up.
2. More likely the bushing on which the spindle rotates has worn larger, perhaps with the spindle shaft itself worn smaller. As a result of a smaller shaft in bigger hole, the shaft no longer rotates about an axis but wobbles into a diagonal position, like this: |\| Instead of |||. The angle allows the half-moon to make contact.
Correct assembly procedures and all the needed parts are diagrammed in the Factory Service Manual available on this site. I suspect you'll be needing a few new parts to make this work right again.
Re: oops !!
Posted: Sat Mar 05, 2011 9:14 pm
by Saved
That's a definite oops...
Re: oops !!
Posted: Sun Mar 06, 2011 12:36 am
by noiseguy
Check the assembly diagrams / microfiche to ensure you've got all the right parts in all the right places.
Gears don't usually chew up on one side like that. There should be matching damage on another surface. Look for it.
Doubtful case would have done that... steel gears win on Al castings. Either damage from kicking (misalign) or damage while running (grinding on something.)
Re: oops !!
Posted: Sun Mar 06, 2011 12:15 pm
Now that I can see the Bucket pics, I have a better idea:
It looks like the sliding spindle that engages the Drive Pulley didn't disengage for some reason. If so, that part is probably munged too, along with the Castle teeth on the spindle and perhaps the drive face as well.
