Electrical / Battery question
ryanmcfinney
Post by ryanmcfinney »
Any idea of how I should test to see if a battery needs to be replaced? The electric starter has not worked since I got her and nothing works unless its running. How long should I have to ride it to give the battery an appreciabe charge if it will take one? Any tests you can think of? Any advice would be great!
edwardzx7
Post by edwardzx7 »
get a voltmeter,if u use it right could be your best friend.
Image-$show your right$
uspmale
Post by uspmale »
Do a load test.
Using volt meter, check for at least 9 volts. when under load.13 without load.
Does starter make any sound at all?
