disked sprees
disked sprees
i searched but couldn't really find what i was looking for. i have a good deal on a DD front disk setup for only a 100$ from a good friend. Just wondering if anybody has any write ups on how to do this other wise ill just dive right in and make it happen. some pics would be nice if anything. aloha
TURN1
Re: disked sprees
Might not get the step by step instructions from here.
I've only seen HI peeps do the DD50 custom front end swaps.
It would do the community a great service, if you put together an info sheet on the mod.
Youtube vid would be great
My friend Jon did it on his EVE SMILE. There should be pics on FH. Requires cutting and welding. Need to use a Monkey front fender or try to cut up the stock on to fit.
Good luck. Its a great upgrade to any drum brake Honda moped.
Pass on the ALOHA Spirit!!!
Re: disked sprees
yeah ill try and do a pic intense write up on the build. The bike is just a frame right now but when i acquire enough parts to begin i will make a thread specifically for this bike
Re: disked sprees
viewtopic.php?f=1&t=12346&start=45
you can use the af16 motor mount. Then you will need to cut 99mm on the left from the right. On the front only..
